Author Topic: The Bleeping 400f Air Box - A Tool  (Read 708 times)
Offline Eldrick
« on: May 15, 2022, 01:13:21 PM »
Time to give to the forum, I was looking at posts and videos about getting the air box onto the carbs after the carbs were installed. I tried yesterday, even with my heat gun and failed.
Today I made a tool out of wood and fitted the box very quickly.
Here are a few photos of what I made.
Oval shape, using the metal link part that goes into the airbox as a pattern.
It is one and a half inch thick, give or take...
In situ ready to put some pressure on the, well that part that never goes over the carb to easily.
Wrench to apply the pressure.
So, one hand on the wrench one on the screwdriver and I was pleased
1975 Honda CB400f - Red
Offline Eldrick
Re: The Bleeping 400f Air Box - A Tool
« Reply #1 on: May 15, 2022, 01:15:14 PM »
the wrench photo went missing
« Reply #2 on: May 15, 2022, 03:34:40 PM »
Geat tip Eldric.
That looks a neat idea, really easy without any tool if you have no rear wheel or mudguard fitted - as you say an absolute  pig otherwise.
I'll look at making something like that next time I have to do it in situ. Did you look at using a long bolt instead of two long screws or does that make getting in situ impossible?
« Last Edit: May 15, 2022, 03:37:28 PM by McCabe-Thiele (Ted) »
Offline Eldrick
« Reply #3 on: May 15, 2022, 05:42:01 PM »
Geat tip Eldric.
I just don't have bolts so used what I had.
