Author Topic: Crankcases assembled but can't select gears  (Read 2467 times)
Offline ebmbiker
« on: May 26, 2022, 11:44:04 AM »
Hello again folks,
I've got my crankcases assembled, no top end on. When I rotate the input shaft by hand and use the gear shift lever, it won't shift through the gears. The selector drum only rotates a small amount. The shafts rotate easily and the output shaft is engaged and rotating.
Any ideas?
"Fast Beat The Feet!"
Re: Crankcases assembled but can't select gears
« Reply #1 on: May 26, 2022, 12:06:49 PM »
Did you assemble in the top case or bottom case?
Offline ebmbiker
« Reply #2 on: May 26, 2022, 12:18:31 PM »
I assembled in the top case. I'm using the Haynes manual.
« Reply #3 on: May 26, 2022, 12:58:57 PM »
Is your engine on the bench or in your bike?
If it's on the bike is the lever unimpeded?
Offline ebmbiker
« Reply #4 on: May 26, 2022, 01:14:06 PM »
Engine is on the bench Ted.
Offline ebmbiker
« Reply #5 on: May 26, 2022, 01:24:07 PM »
These are the limits of movement of the selector drum
Offline ebmbiker
« Reply #6 on: May 26, 2022, 01:24:56 PM »
Second position
« Reply #7 on: May 26, 2022, 01:46:20 PM »
Sorry I do not think I can help you as it's outside my limited knowledge.
Only question I would ask is was the gear selector drum/selector forks  in the neutral position when you assembled the gearbox internals ?
Offline ebmbiker
« Reply #8 on: May 26, 2022, 01:55:01 PM »
I can't be sure if it was in neutral. The shift drum guide screw [the part that screws in from the top of the crankcase] that I have is the later version without the ball and spring. So there's nothing to fit into the detent on the drum.
« Reply #9 on: May 26, 2022, 02:28:58 PM »
I’m no expert and the photo is upside down. But that drum appears to be 180deg out of position. In the neutral position the wheel should be nestled in the neutral drum recess. So you might be correct Ted. The gearbox my not have been assembled in the neutral position.
Offline ebmbiker
« Reply #10 on: May 26, 2022, 02:34:03 PM »
Makes sense. I'll start dismantling it! Everyday is a school day!
« Reply #11 on: May 26, 2022, 02:35:22 PM »
Like this
« Reply #12 on: May 26, 2022, 02:44:01 PM »
Is the cam plate correctly assembled. It’s difficult to get wrong as only one locating pin is ‘raised’ relative to the others. If not the drum is in the wrong orientation, which is equally difficult to get wrong! Good luck.
« Reply #13 on: May 26, 2022, 02:51:28 PM »
I'd say you are right Phil, the top roller goes into the indent in the pin plate when it's in neutral, it's so you get a positive selection of neutral when you need it.
Offline ebmbiker
« Reply #14 on: May 26, 2022, 03:02:56 PM »
Cheers guys for the continued advice and wisdom. I need to get an M12 X 1.25 metric fine bolt so I can draw the primary shaft off. My car mechanic mate might have an actual slide hammer.
