Author Topic: How to remove cylinder head location sleeves  (Read 829 times)
Offline ebmbiker
« on: June 06, 2022, 11:27:38 AM »
Hello again folks,
How do you remove the 2 cylinder head to barrels location sleeves?
Cheers, JB
"Fast Beat The Feet!"
Re: How to remove cylinder head location sleeves
« Reply #1 on: June 06, 2022, 12:41:55 PM »
Why do you want to remove them? Either, push a drill bit the same diameter down inside and grip the outside with a pair of mole grips, wiggle and it may come out. Or, just clamp with mole grips, this will crush the dowel and wreck it but it will remove it.
I have stock of them if you need new ones.
Offline ebmbiker
« Reply #2 on: June 06, 2022, 01:21:56 PM »
My steel liners are a little bit proud of the surface when I pull my fingernail across it. So I'm going to flat it on my surface table or give it a light skim on the Bridgeport.
« Reply #3 on: June 06, 2022, 01:25:28 PM »
Ah, OK, so they need to come out then. Why not try just heating the barrels in the oven, the liners should drop down so they are level. They would have been level when they left the factory so unless someone has been playing around in the past, they should be level now.
Offline ebmbiker
« Reply #4 on: June 06, 2022, 01:33:24 PM »
Thanks Nurse Julie!
Lightbulb moment!
I've already heated the barrels in the oven once to cure the Simonez paint so they must have moved then! I'll bake them again tonight, but this time I'll support the base so the sleeves are clear and can slip back down.
« Reply #5 on: June 06, 2022, 01:37:39 PM »
I did the same. I didn’t notice until I tightened the head down. The relocated with an almighty cracking noise. A real heart stopper.
« Reply #6 on: June 06, 2022, 02:14:40 PM »
Thanks Nurse Julie!
Lightbulb moment!
If they don't drop down on their own after heating, give them a whack with a plastic mallet.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #7 on: June 07, 2022, 01:04:11 PM »
Recently had the same problem, but shown how to remove the location sleeves using flush side wire cutter. If necessary shove a drill bit down to hold its shape, but in my case all came out simply levering the sleeves up with the wire cutter.
Minor damage for sure to the sleeves, but easily dressed out…
