Author Topic: Broken - carb  (Read 685 times)
oldchuffer
Broken - carb
« on: July 03, 2022, 02:45:19 PM »
In my haste to separate carb no. 1 from the bank i seemed to have snapped what i assume is the fuel connection between carbs 1 & 2. Can anyone tell me if these are available? i cant seem to see a part number in the parts book. See pic.  I would need 2 as i see the link between 3 & 4 is missing. But the fuel feed which goes between 2 & 3 looks ok. [ Guests cannot view attachments ]
Re: Broken - carb
« Reply #1 on: July 03, 2022, 04:01:33 PM »
It is not available seperately, i MAY have some 400 carb bits i will look later
oldchuffer
Re: Broken - carb
« Reply #2 on: July 03, 2022, 06:51:13 PM »
Thats very good of you, many thanks.
Offline flatfour
Re: Broken - carb
« Reply #3 on: July 03, 2022, 07:00:46 PM »
I have a set of 350 carbs in the shed, if they are the same as those for a 400. I'm not sure of the condition, however I think that the bodies are probably usable.
I'm away until Friday, however if you're not sorted out by then I'll happily take a look for you.
oldchuffer
Re: Broken - carb
« Reply #4 on: July 05, 2022, 05:11:41 PM »
Think i'm sorted now, thanks all.
