Author Topic: Carburettor overhaul company  (Read 1018 times)
Online Gromitdog
« on: July 04, 2022, 10:00:55 AM »
Good Morning All
Mutely is not well !  I have a set of Honda CB 550 K3 KEIHIN 6273 carbs N03 crab has started to weep and doesn't seem to want to stop even after a good run down the road ( checking behind me 1st  ;D ) This might be a good time to have the carbs sonically cleaned and etc and reassembled can anyone recommend a company that could do this as I am not confident enough to do this on my own I live up in NE Yorkshire area so if a company is up this way great.
Thank all for taking the time to read this any help and advice would be most appreciated.
Best Regards
Gromitddog. & Mutely the bike
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
Re: Carburettor overhaul company
« Reply #1 on: July 04, 2022, 10:30:46 AM »
550K3 should have PD carbs not the ones you have which are for an F. 500 carbs are same except jets.
I only know of one person doing carbs and they are in Holland and cost over £300 now due to the B word
« Reply #2 on: July 04, 2022, 02:35:30 PM »
You sure it's not 627B not 6273?
« Reply #3 on: July 04, 2022, 04:21:07 PM »
Remembered its Gerben in Holland
Offline cliff7
« Reply #4 on: July 04, 2022, 04:37:00 PM »
Is Matt Harper (Nantwich) still doing carbs?
« Reply #5 on: July 04, 2022, 04:56:53 PM »
Yes, Matt is still doing carbs and does some Honda SOHC/4 ones, as he buys the Viton O ring kits from me. I've never used him myself though for carb overhauls.
« Last Edit: July 04, 2022, 05:15:32 PM by Nurse Julie »
« Reply #6 on: July 04, 2022, 06:54:38 PM »
I don’t believe that’s a recommendation to use PD carbs.
« Reply #7 on: July 04, 2022, 07:49:52 PM »
PD carbs are definitely a challenge. Reluctant to deliver enough fuel to start the bike from cold and tight fisted with fuel around mid-range. Apart from that there fine. 😂😂
1978 Honda CB550K3.
