Author Topic: Fuel lines from carbs  (Read 802 times)
Offline Matt_Harrington
« on: July 11, 2022, 06:17:37 PM »
Could someone tell me how long these lines are that are labelled (2)
Do they just 'dangle down' in case of an overflow?
Item (1) was very hard and difficult to remove but I can replicate that one easily.
Re: Fuel lines from carbs
« Reply #1 on: July 11, 2022, 06:31:22 PM »
If you make them about the same length, once fitted, as the float bowl drain tubes, that'll be about right. They are air vent tubes, they just dangle down to atmosphere.
« Last Edit: July 11, 2022, 06:33:55 PM by Nurse Julie »
« Reply #2 on: July 11, 2022, 06:35:48 PM »
Ta very much! I'll let them dangle!  ;)
Offline ka-ja
  • ken
  • yoshi 460
« Reply #3 on: July 11, 2022, 07:50:27 PM »
They fall between the rear of the engine casing and the frame, and are held together in a square shaped plastic former.
nice bike,nothing in the bank
Offline Deano400
« Reply #4 on: July 11, 2022, 09:41:48 PM »
The two carb vents go over the air manifold and down between the crank case and swing arm.
« Reply #5 on: July 12, 2022, 02:45:01 PM »
Thanks - those are useful for the routing. Matt
