Author Topic: Axle Wrench  (Read 2101 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Axle Wrench
« Reply #15 on: August 14, 2022, 08:18:45 AM »
Sorting out the K2 toolkit - can anyone advise me what the ‘Lever’ and the ‘Bar B, Handle’ are for? The lever does not accept the screwdriver bits, and the Bar B jaws are 8mm wide fyi.
At last I have the Sandcast axle wrench in my hand; a bit of a result as it appears NOS complete with parts bag / label. The rest of the kit is fair, and the tool-bag original & immaculate which is another win. It has a 0.7mm plug feeler in the pocket which is not CB750 (CB500?) and mint. I’ve an OEM 0.5mm inlet feeler in the post, but still searching the 0.8mm exhaust part.
If anyone has this I’ll swap the (CB500?) OEM plug feeler .. or ask your price?
I thought bloody mortgages were behind me 😂. And certainly I wouldn’t want to use the axle wrench in anger.
The wrench is indeed 26mm as you thought Ken, and the smaller hole 23mm (Front axle nut?)
« Last Edit: August 14, 2022, 08:33:56 AM by Lobo »
Re: Axle Wrench
« Reply #16 on: August 14, 2022, 08:31:44 AM »
The lever should accept the reduced bit at top of screwdriver blades and general opinion is that wrench is a not very good spoke nipple key
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Axle Wrench
« Reply #17 on: August 14, 2022, 08:53:49 AM »
Ah thanks Bryan… you’ve cleared up the lever issue as I’d inserted double-ended bits into the ‘kit, not realising the single ended bits have that additional reduced bit. Sorted now….
Wrt the Bar B, it’s nowhere near a spoke wrench as the nipples are 6mm or so, and the jaws 8mm. Unless of course I’ve some odd pattern part in the K2 kit?
Re: Axle Wrench
« Reply #18 on: August 14, 2022, 11:47:26 AM »
Can't exactly remember but could the C spanner be for tappet adjustment.
I had a Snap On set of feeler gauges for when I was in the trade, the beauty of them was the feelers could be replaced when you either broke them or as often happened they went into a curl. I bought quite a few spare blades for when that happened and still have them. They are marked both thou and mm. They look almost the same (if not the same) as the Honda one in the kit. Can't remember exactly but is 0.8mm 3 thou? and 0.5mm 2 thou? I bought quite a few of those sizes as they were common back in the day for tappets so I've most likely still got a couple left.
Just found them and I've bought a shed load of 4 and 6 thou, probably because the 250N and 400N used that size. No 2 or 3 thou left and even my set is missing the 2 thou blade. Must fix that.
Saying that I also found a set of blades I bought off Ebay recently that has removable blades, maybe something like that would be ok for you.
https://shop.snapon.com/product/Feeler-Gauges%2C-Bent-and-Step-Ground-Blades/0.030%22-(0.762-mm)-Flat-3%22-Feeler-Gage-Blade/FB1B030
« Last Edit: August 14, 2022, 12:06:22 PM by Oddjob »
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Axle Wrench
« Reply #19 on: August 14, 2022, 12:53:00 PM »
Cheers Ken - appreciate this; looks hopeful.
It’s hard to find info on the blade I’ve ordered - I’m reckoning it’s the smaller size, though no real idea. Once I receive it I’ll know the remaining size to order.
And yep, you’re right with the CB750 valve settings …
Wrt the Bar B, I just can’t find anything to suggest it’s use. And what is Bar A!!! Why can’t they call it what it does? 😠
I’ve not had a ‘cap off to test your theory, but it just feels way to bulky to be getting down the rocker hole to the locknut. Maybe tomorrow….
Re: Axle Wrench
« Reply #20 on: August 14, 2022, 12:55:42 PM »
Locknut is 10mm, Ken 40thou to the mm so 0.8 is 32thou, is it not 0.08?
Re: Axle Wrench
« Reply #21 on: August 14, 2022, 01:57:27 PM »
Probably Bryan, I know what I meant though  ;D ;D
If you ever see Snap On vans in Oz maybe just stop and ask if he has one onboard. If not you can get them to order one.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Axle Wrench
« Reply #22 on: August 15, 2022, 10:56:14 PM »
Having a cuppa tea with Lindsay yesterday (engine builder) who too wasn’t sure what the Bar B tool is for. He identified the throttle cable adjuster barrel as the only 8mm piece on the bike, and suggested this is why Honda added those jaws to the plug socket bar. Makes sense…
Ken, found a 3” set of feelers in a local tool store so have a Pan B in place. Many thanks.
Offline Seabeowner
Re: Axle Wrench
« Reply #23 on: September 02, 2022, 08:55:59 AM »
I see Roger Etcell has one listed at present.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Re: Axle Wrench
« Reply #24 on: September 02, 2022, 12:49:01 PM »
I'm off back to the states in a couple of weeks and I know the chap I see there has totes and totes of all the bits and bobs from tool kits from scrapped Honda's from the last 40 years (and teh packets and plastic covers etc.) If you are desperate, when I go i'll have a rummage if you let me know exactly what you need. If that helps let me know. He GAVE me a complete set for my 550 FOC, hes a top bloke and might be a problem solver for you at a push.
Re: Axle Wrench
« Reply #25 on: September 02, 2022, 03:01:01 PM »
If you see any plug spanners for the 500 Roo, genuine ones not copies, get me a couple please.
Re: Axle Wrench
« Reply #26 on: September 02, 2022, 03:06:24 PM »
of course mate.
