Author Topic: Rear brake on CB550F question about design  (Read 1062 times)
Offline alexdecker
« on: July 21, 2022, 06:42:40 AM »
Hey all
Assembling the rear brake. The brake pedal stem is a slightly different design than earlier models it seems, and it has an extra arm with some sort of hook on it. I can't figure out what the hook is supposed to hook on to or what its purpose is. Can anybody help?
Offline alexdecker
Re: Rear brake on CB550F question about design
« Reply #1 on: July 21, 2022, 06:48:02 AM »
Mmh… realising right now it must be the spring it hooks on to! Already installed the back wheel though, and it seems I have to disassemble that again to even install the brake pedal stem. Damn.
Online Bryanj
« Reply #2 on: July 21, 2022, 07:36:04 AM »
Swing arm out as well
Offline alexdecker
« Reply #3 on: July 21, 2022, 09:39:52 AM »
Ok, the spring is on the outside of the bike, not inside where that hook is. Can someone tell me or if anyone has a picture of how to mount this correctly? What goes in that hook on the second arm of the brake stem?
Offline Bro550F
« Reply #4 on: July 21, 2022, 11:22:57 AM »
Any photos, would help??
« Reply #5 on: July 21, 2022, 12:17:46 PM »
Does this help?
Offline FlyinPhil
  • Potestatum Obscuri Lateris Nescis
« Reply #6 on: July 21, 2022, 01:15:33 PM »
I made this mistake as I followed a build thread from an earlier K model and then found out when I had installed the lovely new swingarm and rear wheel that I couldn't get that brake arm pedal in.  So out came the rear wheel and swing arm again to install it.  I just put it down to experience and its all part of the fun, and yes the little hook is for the little spring which connects the arm to the brake pedal switch.
1977 CB550F
"She's built like a Steakhouse, but handles like a Bistro."
« Reply #7 on: July 21, 2022, 04:08:19 PM »
I was fortunate not to make a similar error on my 400 - when asking about fitting the bronze bushes into the swing arm I was forwarned about fitting the brake pedal lever before fitting the swing arm into the frame.
Offline alexdecker
« Reply #8 on: July 21, 2022, 05:15:46 PM »
I did exactly this :) Ah well, corrected the error today.
One question though - does anyone know where the brake pedal adjuster bolt is on my model? I can't find it on the parts list.
Online Bryanj
« Reply #9 on: July 21, 2022, 05:31:23 PM »
EITHER outside the frame pushing down on the pedal OR behind the frame tube pushing on one of legs of the bit you cant fit
Offline Seabeowner
« Reply #10 on: July 21, 2022, 06:54:42 PM »
Brake pedal adjuster bolt hole is inboard of the main frame tubes. Short bent bit of meatal for 6mm bolt that bears on the back of the arm that the pulls the brake rod. The other arm on the this shaft with the hook is for the spring of the rear brake switch.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline alexdecker
« Reply #11 on: July 21, 2022, 08:43:50 PM »
Ok, so something weird here.
When I took the bike apart, this screw was placed in that screw hole:
But when I try to refit it now, it seems the screw is too big, and is ruining the thread. See this picture. Don't know if it is just because of the powder coating, but it definitely seems as if the screw is way to big for the hole.
But I have a before picture of that screw in that exact hole! What do you guys think?
« Reply #12 on: July 21, 2022, 08:54:20 PM »
If you are certain you  took that bolt out of the thread and it seemed normal then a tap down the thread should  remove any powder coating layer.
« Reply #13 on: July 21, 2022, 09:39:03 PM »
TBH it looks like the bracket is bent out of shape, it should be flat and it should be threaded M6 x 1.00, that bolt could be UNF as it appears a bit coarser than standard.
« Reply #14 on: July 22, 2022, 07:38:15 AM »
Second oddjob comments. The plate should be flat eg perpendicular to the brake arm.
