Author Topic: Rear brake on CB550F question about design  (Read 1176 times)
Offline Bro550F
Re: Rear brake on CB550F question about design
« Reply #15 on: July 22, 2022, 08:21:25 AM »
As mentioned above, straighten bracket so it's perpendicular to the plate, then run the tap through the hole and offer the bolt to the tap to check the threads are the same before trying to force the bolt in. After tapping it should go in by hand.
