Author Topic: twin disc  (Read 2357 times)
Re: twin disc
« Reply #15 on: September 08, 2022, 10:43:32 AM »
Aside from the different swept volumes for an equal amount of lever movement the resultant lever effort on each master cylinder piston  per square cm will make the brakes feel heavier to apply on a larger piston to give the same pressure at the caliper end. Hence the loss of lever feel on braking with larger bore M/C's.
Imho
« Last Edit: September 08, 2022, 08:53:22 PM by McCabe-Thiele (Ted) »
