Author Topic: 550F2 DSS Wiring Harness  (Read 1334 times)
Offline FlyinPhil
  • Potestatum Obscuri Lateris Nescis
« on: July 24, 2022, 02:10:45 PM »
I've reached the point I've been dreading in my build and that is the wiring. Me and electrics should have a restraining order against each other, as it is, in my opinion the work of the devil.
However, I've come to install the loom today however I have a lot of wires which simply do not match the plethora of wiring diagrams I have.
The loom is a brand new one from David Silver Spares and I wondered if anybody else here had experienced the same problems? For example, the wiring diagrams state brown wires running to the tail lights, however the loom doesn't have a single brown wire in it anywhere. The loom also has an orange with black stripe wire, but this is not on any wiring diagram.
The old loom removed matches all the diagrams perfectly and I'm now feeling rather lost. I'll give DSS a call tomorrow to see if they can help but thought I would also reach out to you guys for any advice.
1977 CB550F
"She's built like a Steakhouse, but handles like a Bistro."
Re: 550F2 DSS Wiring Harness
« Reply #1 on: July 24, 2022, 02:31:34 PM »
Have you compared the old loom colours with the new ones from the front to the rear including any wiring spurs / clusters along the length?
« Reply #2 on: July 24, 2022, 02:50:42 PM »
DS looms are well known for using the wrong colour wires.
Sure there was a thread recently with the colours converted to the Honda ones.
« Reply #3 on: July 24, 2022, 03:02:15 PM »
Too late now but I got mine from this firm the colours were identical to the original.
https://www.electrexworld.co.uk/cgi-bin/ss000001.pl?page=search&SS=Honda+CB750&PR=-1&TB=O&ACTION=Go%21
« Reply #4 on: July 24, 2022, 03:07:57 PM »
They don't do a 550F though Ted.
The 550K won't fit, wrong harness.
I was lucky and found a NOS one for my 550F2, not 100% sure if I'll use it yet as the old harness is still in decent shape but until you try to use the old harness you can't be sure.
« Reply #5 on: July 24, 2022, 03:10:08 PM »
Offline FlyinPhil
« Reply #6 on: July 24, 2022, 04:51:25 PM »
Hi Ted, yes I have, the old loom is spot on to the wiring diagrams but the new one is totally different with only a couple matching colours unfortunately.
1977 CB550F
Offline FlyinPhil
« Reply #7 on: July 24, 2022, 04:53:57 PM »
Al does one for the F2.
https://alans-electrics.alanlowe.co.uk/honda-stock/honda-2
Cheers Oddjob, I'll call DSS as I can't believe they advertise and sell these looms for this bike but are completely bloody different. Those ones from Alan's are rather pricey in comparison too but I suppose you get what you pay for.
1977 CB550F
« Reply #8 on: July 24, 2022, 05:37:27 PM »
If you can use a multimeter it can be sorted BUT long distance electrics is not easy!
You could bring it to Gloucester and i will sort it
Offline FlyinPhil
« Reply #9 on: July 24, 2022, 05:57:44 PM »
Thanks that's really generous of you, I can use a multimeter no probs I think as I now realise that this DSS loom doesn't match I just wanted to rant that a company like that could be so half-assed about it. I mean if it said in the advert that it doesn't match oem I would of sourced another elsewhere. I just want the loom to match the original as it will make life so much easier for a newbie like me. I'll probably end up just sending it back and buying one from Al on here.
1977 CB550F
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #10 on: July 24, 2022, 05:59:39 PM »
Do you have images of the DSS CB550F1/2 wire harness?
Old original wire harness attached...insulation colour reference
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline FlyinPhil
« Reply #11 on: July 24, 2022, 06:39:20 PM »
Hi Al, I can get some but I've installed it on the bike so might be hard for me to show it in any real detail. Looks like I will just have to buy one of yours instead. Its really grinding my gears this DS one, the advert even states and I quote:
 'The highest quality reproduction wiring harness, a perfect replacement for the original which is no longer available from Honda.'
Utter bullish!t. I have my old original harness which I've been using as reference, however from years of classic car ownership I know how critical a good electrical system is so wanted it all new. What photos would you want?
1977 CB550F
« Reply #12 on: July 24, 2022, 07:36:30 PM »
Head light shell wiring would be good.
Image attached of the old CB550F1/2 loom head light shell wiring connections.
Current bikes:-
Offline FlyinPhil
« Reply #13 on: July 24, 2022, 09:16:21 PM »
Al, attached are photos of the DS headlight wiring, the centre loom for the switch gear, the taillight wiring and the fuse box block connector. All of which are totally different to stock.
1977 CB550F
« Reply #14 on: July 25, 2022, 09:16:26 AM »
Far too many insulation colour changes in the DSS loom
Red/white should be Green...frame earth
Green/blue---:---Brown/blue
Blue/white---:---Brown/white
& many other wire colours/connectors are in the wrong position?
Image attached of the OE rear loom lighting connections...as most classic Honda's
Current bikes:-
