Author Topic: Carb rubbers  (Read 807 times)
oldchuffer
Carb rubbers
« on: July 24, 2022, 05:48:13 PM »
Probably been asked before but my carb to engine rubbers are rock hard. Is there a way to soften them up or is it a case of buying new ones? If so can anyone recommend a source?
Re: Carb rubbers
« Reply #1 on: July 24, 2022, 06:53:56 PM »
Silvers sells sets
Online McCabe-Thiele (Ted)
Re: Carb rubbers
« Reply #2 on: July 24, 2022, 07:04:52 PM »
From my memory they are pretty firm anyway. I've seen a post about soaking them in  Evergreen oil  something  or other to soften them.
Amendment: Not Evergreen but Wintergreen as per later posts.
« Last Edit: July 25, 2022, 10:12:13 AM by McCabe-Thiele (Ted) »
Re: Carb rubbers
« Reply #3 on: July 24, 2022, 07:18:13 PM »
Warm them up with a hot air gun.  They get quite soft and rubbery.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Carb rubbers
« Reply #4 on: July 24, 2022, 10:31:35 PM »
…just been through this whole exercise with ‘750 intake rubbers, one of which had become distorted in situ. Hot air, long soak in Wintergreen did soften them…. temporarily.
Given I had the bank of carbs out and the poor seal the distorted one was making, I just bit the bullet & bought a new set.
If you’re talking CB400F, good luck with getting the airbox back with any reluctant rubbery bits!
Re: Carb rubbers
« Reply #5 on: July 25, 2022, 09:45:38 AM »
I agree fitting the 4 into 1 air box is far from easy when everything else is in place.
Having done this twice before my rebuild I found that assembly was much easier when the rear mudguard, wheel and battery box are not in place - then fitting the carbs, air box working backwards was far easier.
oldchuffer
Re: Carb rubbers
« Reply #6 on: July 25, 2022, 11:41:10 AM »
Thanks for the tip Ted.
