Author Topic: Trying to source these rear signal light brackets + rubbers. Help please?  (Read 1727 times)
Offline mickwinf
Just for information, the f2 rear indicator bracket is pretty unique, the problem is the distance between the mounting screw and the locating post that go through the rubber. the distance is different to all the older 500/550 ones so they do not fit even though they look similar. They do come up occasionally in usa, the mount and rubber are the same as american spec but the stem is for the later bigger indicators, not the uk spec smaller indicators. Very hard as said to find the stems, i was lucky and found some in a job lot i bought. I think i have a spare mounting bracket and rubber if that helps?
