Author Topic: Wanted CB400/4 Rear Grab Handle, Engine Bars, and Luggage Rack  (Read 973 times)
Offline rbt1548
I am looking for the grab handle that fits on the rear of the bike and bolts between the rear shocker and frame, one would do but two would be better as it would balance up the rear.
Also a set of Engine bars and a luggage rack.
Re: Wanted CB400/4 Rear Grab Handle, Engine Bars, and Luggage Rack
« Reply #1 on: July 31, 2022, 11:01:17 AM »
David Silver did have the lifting handle available.  Only fitted on the left hand side normally, to help lift bike onto centrestand. They had engine bars as well, but a bit lightweight compared to period ones.
For a luggage rack contact Renntec, they should be able to help you.
Incidentally,  if you fit a rear luggage rack you won’t need the lifting handle as well.
« Reply #2 on: July 31, 2022, 12:30:18 PM »
dont know if I kept the one that came off ours, I'll have a look later when I get home for you. If we did, I think I know hwere its at.
« Reply #3 on: July 31, 2022, 09:13:45 PM »
The DS part is a larger diameter grab handle tube than the original. I have a new
 original copy that I bought from a member here - it might have been David Horton he had some high quality chromed ones. Might be worth a PM to him.
« Reply #4 on: August 01, 2022, 07:07:26 PM »
Sorry one shed cleaned out n re set and cant find ut there but another one to sort through tomorrow.........
Offline rbt1548
« Reply #5 on: August 02, 2022, 08:52:57 AM »
Thanks very much, info much appreciated.
I did notice DS had some grab handles and engine bars, if I could get a set of the more substantial bars I would, if not will probably settle for DS ones.
The reason I was going to go for 2 grab handles was, I don't carry a lot and not that often, maybe a weekend cylindrical tote type bag, so thought I  could use the 2 grab handles to secure the bag to if I just put the bag on the seat.
I will have a look at the Renntec site and see what is available.
« Reply #6 on: August 02, 2022, 11:17:53 AM »
Hiya,
haven't managed to find the grab rails I had, sorry about that, they must have made it to the scrap bin. Apologies
« Reply #7 on: August 02, 2022, 11:23:29 AM »
Did you try Peter Horton his name here is kent400.
If he has none left I have one of his to spare - its a new pne never fitted.
PM me if he has none left & if you want mine it will be at CP plus postage.
« Last Edit: August 02, 2022, 12:06:01 PM by McCabe-Thiele (Ted) »
Offline rbt1548
« Reply #8 on: August 02, 2022, 04:55:13 PM »
Thanks for that I will do, I tried searching in 'members'  for David Horton, that was the name in the earlier post, no wonder I couldn't find him ;D ;D, was that not the guy in the Vicar of Dibley? ;D
Thanks again
« Reply #9 on: August 03, 2022, 06:12:08 PM »
My bad I knew it was Peter but typed David. I knew no good would come of a lady vicar.
