Author Topic: Noisy steering head  (Read 1298 times)
Offline Athame57
    • SeaWitch Artist
Noisy steering head
« on: August 02, 2022, 10:37:57 AM »
Sometimes especially when I first start out I'm getting a noise like a rusty derelict crane turning slowly in the wind,  :o I've looked all over to no avail, anyone know a usual suspect I can go back and check?
1978 CB400F2 called Elen.
Re: Noisy steering head
« Reply #1 on: August 02, 2022, 10:56:10 AM »
My first suspicions would fall on the steering shaft area - have you recently fitted replacements - if so could they be a tad on the tight side or is there a shimming issue ?
There seems to be a very poor bottom seal design that fails to keep out water.
I might have misunderstood the crane turning!
« Last Edit: August 02, 2022, 10:58:22 AM by McCabe-Thiele (Ted) »
Online taysidedragon
« Reply #2 on: August 02, 2022, 11:03:20 AM »
Do you mean the noise is from your creaky bones or from the bike?  :D
Offline Athame57
    • SeaWitch Artist
« Reply #3 on: August 02, 2022, 12:47:10 PM »
Maybe it is me. I've been very inactive for months due to illness, and maybe some WD40 would do me good as well. I don't hear these noises at other times though so I doubt it!  ;D
« Reply #4 on: August 02, 2022, 01:30:10 PM »
I drilled and tapped my headstock, fitted a grease nipple and it's now completely full of grease. One thing about steering races etc is that you cannot easily regrease them unless of course you do what I did. If you've got tapers fitted it could be the bottom race isn't shimmed out enough, check the bottom of the frame for rubbing marks. Or it could be a lack of grease or the grease has started to dry out in the very warm weather we've had recently.
« Reply #5 on: August 02, 2022, 01:39:29 PM »
You could do a "std headache setting check" sir  :)
Put you left index finger underneatth the top yoke next to the bearing, entry point about 7 o'clock with finger tip going round to 1 o'clock, hold front brake with right hand and rock bike (both wheel on ground) back and forth.
Any slack and you'll feel immediately the headstock moving as you rock it with vehicle weight on it.
« Reply #6 on: August 03, 2022, 09:38:13 AM »
Reads like the Prostate finger of fudge test.
« Reply #7 on: August 03, 2022, 10:40:26 AM »
 ;D ;D ;D
Offline TrickyMicky
« Reply #8 on: August 03, 2022, 08:19:53 PM »
I cannot fathom out how the headstock bearings would be making a noise when riding. Surely the handlebars are not moved to any great extent, and if they were knackered enough to make a noise then surely you would feel it through the poor handling. If it only occurs when starting out, I would be looking at the rear chain and wheel bearings. Try and enlist the help of a friend and give you a push along the road with a dead engine. I'm in the middle of cobbling together a CL160, and being a tight git I refitted the original drain pipes from the float bowls. They were fairly rigid after 55 years but I got them into position.  Refitted the rear wheel, chain, chain guard, and spun the rear wheel by hand. The noise was awful, you, you've guessed, it was the end of one of the drain pipes making love to the chain! Think outside the box and look everywhere.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #9 on: August 04, 2022, 09:52:22 AM »
Just a thought - you didn’t apply the book 60+ ft lbs of torque to the Steering Head Top during any rebuild did you? (That torque is for the uppermost / chromed nut). The steering head Top threaded piece is almost finger-torque tight, and is the hidden ‘nut’ immediately on top of the bearings.
Regardless, a strip down is warranted?
« Last Edit: August 05, 2022, 02:45:55 AM by Lobo »
Offline Athame57
    • SeaWitch Artist
« Reply #10 on: August 15, 2022, 06:00:24 PM »
I found the energy to overhaul my squeaking front brake ;D  ( I was really ill a long time post op) and in went the new fluid, and the copper grease plus a noticeable amount of rust, and the pad to disc clearance adjusted.....but what did vanish also is the 'noisy steering head, that can't have been by magic so maybe some brake noise I've never had before was traveling up through the fork stanchions?  :o
« Reply #11 on: August 15, 2022, 09:16:03 PM »
That reads like good news - strangely enough my 400 front brake has started  squealing like mad. I have not filed the pad leading edges so had put it down to bedding in & needing adjustment.
« Last Edit: August 15, 2022, 09:40:29 PM by McCabe-Thiele (Ted) »
Offline Athame57
    • SeaWitch Artist
« Reply #12 on: August 16, 2022, 10:19:20 AM »
So it helps to round off the edges of the brake padding?
« Reply #13 on: August 16, 2022, 11:03:22 AM »
A lot of modern cars have heavilly bevelled edges to the leading edges of the brake pads.
Simon (SPR) suggested the idea to me as I had long forgotten the trick. Just using some abrasive paper on a rubbing down block at a slight angle on the leading edge of the brake pad.
