Author Topic: Wanted carb  (Read 814 times)
Offline Davelu88
Wanted carb
« on: August 04, 2022, 06:06:54 PM »
Hi all , I need a carb for my 550F . It's the second one in from the choke lever as mine is corroded . Cheers dave
Offline Gromitdog
Re: Wanted carb
« Reply #1 on: August 04, 2022, 06:23:36 PM »
Hi Dave
I have a set of carbs taken off my Honda CB550K3 it has a manual choke lever on the L/H side off the carb.
the cabs are Keihin these where only taken off my bike about 4 weeks ago If you are interested I can send you some pictures via emaiL. I would be looking for £150 for them
Best Regards
Nigel
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
Offline Davelu88
Re: Wanted carb
« Reply #2 on: August 04, 2022, 07:05:44 PM »
Hi Nigel , PM sent
Re: Wanted carb
« Reply #3 on: August 04, 2022, 07:31:06 PM »
If they are off a K3 they'll be PD carbs.
The 550F uses 069A carbs and are totally different.
My BIL took his carbs apart the other day, for some reason he had 1x627B carb (No1) and 3x069A carbs. I have supplied him with another bank of carbs correct for his 500, when he gives me the old carbs I'll see if there is a No2 069A carb as I'll be breaking the bank and will be selling the spares off them.
Where's the corrosion Dave?
Offline Davelu88
Re: Wanted carb
« Reply #4 on: August 04, 2022, 08:45:13 PM »
Hi its on the inside , the middle jet is a tad loose where the metal has corroded mine are definitely 069A
« Last Edit: August 04, 2022, 08:49:42 PM by Davelu88 »
Offline Gromitdog
Re: Wanted carb
« Reply #5 on: August 04, 2022, 09:22:10 PM »
Hiya
Not received your pm as yet I have checked the trash & spam to see if they are in there by miss take and they are not so not sure where its gone . I got a complete set of 4 that I are up for sale if that helps you but as Ken has pointed out they are different to yours if you where planning just changing single one .
You have to ask Ken if mine would fit your bike as a bank of 4 ?
Best Regards
Nigel
Offline Davelu88
Re: Wanted carb
« Reply #6 on: August 04, 2022, 09:25:45 PM »
Hi Nigel , yes I just wanted to change one as a whole bank are getting pricey , as Ken pointed out I do not think yours will fit a 550f
Re: Wanted carb
« Reply #7 on: August 04, 2022, 09:34:51 PM »
Dave. I'm away at the moment but I have a load of seperate carb bodies from 069A's at home. If you PM Graham and tell him which one you need, he can have a look for you.
Re: Wanted carb
« Reply #8 on: August 04, 2022, 09:38:27 PM »
They might not be wrong Nigel. If they have a choke lever on the left they ain't PD carbs. Whether they are 069a or 627b or even 022a is relevant though.
Re: Wanted carb
« Reply #9 on: August 05, 2022, 06:35:16 AM »
This overview may be helpful.
