Author Topic: Wanted nice ND tach for my 550K1  (Read 744 times)
Offline Erny
  • CB750K7 CB550K1
« on: August 07, 2022, 11:27:33 PM »
Looking for nice, original, 100% working tacho (RPM meter) for my 550K1, green colour, brand ND - like one on attached photo (these are my gauges).
My tacho is "hanging", means when I close trottle, it takes quite some time hand lowers down... Also on opposite, when revving up, there is delay till hand react and raises up, so looking for replacement original.
CB750K7 US model (1977)
CB550K1 US model (1975)
Re: Wanted nice ND tach for my 550K1
« Reply #1 on: August 08, 2022, 06:24:39 AM »
I have just had the same problem with a ND tachometer. Sent it for a service and found,  The damper was the problem and it appears that either fluid it contained was solidified or there was a tiny piece of grit in the damper.
He  flushed it with cleaning fluid and ultrasonically cleaned it a couple of times before refilling.
« Reply #2 on: August 08, 2022, 10:37:12 AM »
Erny, I would highly reccomend Peter Horton to refurbish your clock, he's on here and his work is excellent, worth sending him a PM. I know the postage will likely cost but at least you will get your original clock back and can be sure it will be 100%.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
« Reply #3 on: August 08, 2022, 10:42:13 AM »
Kent 400 is Peters name here.
« Reply #4 on: August 08, 2022, 01:15:00 PM »
Not sure those are the original clocks anyway Erny. I seem to recall the faces were light green and those look to be the blue/green faces off a 550F2 or 550K3.
Offline Erny
  • CB750K7 CB550K1
« Reply #5 on: August 09, 2022, 10:33:17 PM »
Thanks for your replies and tips!
For Oddjob - clocks are original.. they are green not blue at all. I know blue ones I have them on my 750 K7.. (I mean colour)
