Author Topic: Battery with 200 CCA?  (Read 395 times)
Offline alexdecker
« on: August 25, 2022, 07:41:56 AM »
Hey
Read on the US forum that it would be preferable with a battery with at least 200 CCA if using the electric starter. My current battery has 165 but is getting a little long in the tooth, so wanted to get a new one. I have not been able to find one in the right size though with 200 CCA. What do you guys run, and why?
Re: Battery with 200 CCA?
« Reply #1 on: August 25, 2022, 09:27:58 AM »
You don't need them. In the US market quantity means quality. The Yuasa I run now is the YB12A-A. It claims to have more CCA than the conventional 12N12A-4A-1. But the next one will be the old type again. First of all: you don't need extra CCA. If your bike doesn't start within some 7 seconds, better stop trying. There will be a cause that needs to be adressed. Moreover, our bikes have a kickstart as back-up. The old type 12N12A-4A-1, costs € 3,- more (!) than the newer type YB12A-A... The extra CCA the YB has, means thinner plates than the old type has. Less robust than the old type on bumpy roads.
« Last Edit: August 25, 2022, 09:30:38 AM by deltarider »
