Author Topic: CB500 spark advancer centre cam  (Read 731 times)
Offline SPR
  • 1972 500/4 K1
« on: August 25, 2022, 05:55:32 PM »
Evening
So just started the change back to points before fitting the Hondaman system and fell at the first hurdle
This is what I have when I've removed the electronic ignition
Apparently I think I'm missing the center cam of the spark advancer which is removed to install the alloy rotar for the electronic ignition.
The whole unit is 30220-323-000 which looks available here https://www.ebay.co.uk/itm/225064173947?epid=1713727851&hash=item3466dec17b:g:~6UAAOSwraNf8yL0&amdata=enc%3AAQAHAAAAoO2yhkUH%2FJi0NnsMLuTZ%2ByGvd2lwQPJhSSvX%2FeX0Sgh3rkDlOLxORYzU7V%2F5UE%2FN6YX8hUWIXs7lKcGsCNqIV1KhLVeIexNrZEVTV6AnVCbY195htb8oXYZqSXqMvm223cKIDryBfh9zlVQtbiC0klNU1pd0FDExj70PTcJ8fhcsMk0NEhY03luyKa%2FepnB3rLErRN35KWA9HwRBmjqJh64%3D%7Ctkp%3ABk9SR_KWnd7aYA on eBay at £40 plus postage
It doesn't seem you can get the cam bit on its own ......
If anyone has the cam or a whole good unit I'm desperate as I'm snookered now till I get the part
Simon
Re: CB500 spark advancer centre cam
« Reply #1 on: August 25, 2022, 06:13:04 PM »
What you doing about the contact plate?
Offline SPR
  • 1972 500/4 K1
« Reply #2 on: August 25, 2022, 06:31:54 PM »
I've got a new genuine Honda one
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #3 on: August 25, 2022, 08:55:11 PM »
I replaced my advance plate/shaft and cam because the plate and shaft were fractionally bent due to the bike having been dropped and the centre small nut went slightly off centre when tightened.
I was fussy and it ran ok but either way the cam part (should be fine), base, arms, springs etc you can have foc. Only a c clip is missing.
This is for a CB500/4 K1.
I’m away until Monday. PM me if that suits.
Regards Jeremy
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline SPR
  • 1972 500/4 K1
« Reply #4 on: August 25, 2022, 10:03:37 PM »
Regards Jeremy
Thanks Jeremy
Pm on its way
Offline JezzaPeach
« Reply #5 on: August 25, 2022, 10:26:39 PM »
Need any more bits?
