Author Topic: Honda Throttle grip adjuster ramp 53163-300-020  (Read 3814 times)
« on: September 16, 2022, 07:12:46 PM »
This is the small metal ramp that fits inside the bottom half of the right hand switchgear on the CB350, CB360, CB500, CB750 and CL360.
It can also be fitted to both the CB400F, CB550F and CB550K if you want to fit one.
This feature was removed from models after the CB500, it was fitted to enable a fast idle for checking advance/retard unit operation for example. In essence it locks the throttle where you want it, this is very handy on motorways for instance when the pressure of holding the throttle open gets a little wearing. Under the switchgear is a large chrome thumb screw fitted with a chrome spring. When this is screwed in it pushes this small ramp up against the throttle pipe, the more you screw the thumb screw in the stiffer the throttle becomes. So on a motorway you just wind in the screw until the throttle stays open by itself. Most of these ramps get lost when you open the switchgear to change bars or a cable for instance. They tend to drop out and you don't notice, fit these with plenty of grease and they stand a better chance of staying in. If you have a CB400F or a CB550F/K you can still fit one by just drilling and tapping the small boss which is still fitted but never used. You need a 5mm tap. Fit the ramp, the thumb screw and spring and you now have this handy feature.
If you have the thumb screw and spring fitted and winding it in does nothing then the ramp is missing. It's just a small piece of metal bend into a special shape. It is quite expensive for what it is, common price is around $7 but it's the postage that kills buying it from the states, I found quite a few last year and bought the lot so as to split the cost to acceptable levels.
Cost is £7 inc P&P. If you buy with a set of clutch shims or felt washers I'll do them for £5.
I have 10 only. Once they're gone, they're gone as the saying goes.
Offline bruxby-clive
Re: Honda Throttle grip adjuster ramp 53163-300-020
« Reply #1 on: September 17, 2022, 01:31:58 PM »
Hi Ken, can I have one of these as well as the shims requested earlier please, any idea when the shims will be ready?
Just because you are breathing, doesn't mean you are alive.
« Reply #2 on: September 17, 2022, 01:33:18 PM »
Done mate, posted on the thread yesterday they were ready.
« Reply #3 on: September 17, 2022, 01:46:03 PM »
Apologies hadn't seen the post until after you replied, £17.00 sent friends and family.
« Reply #4 on: September 17, 2022, 01:48:29 PM »
Have I got your postal address Clive?
Can't remember, if not please PM it.
Payment received BTW. Will send on Tuesday due to Bank Holiday.
Offline martyn916
« Reply #5 on: September 17, 2022, 01:50:39 PM »
Hi Ken,
I'll have one of these please (if you have any left), I'll PM you my details.
Thanks,
Martyn
« Reply #6 on: September 17, 2022, 01:52:43 PM »
Hi Ken, sent you my address on the 7th September in a message, will send it again.
« Reply #7 on: September 17, 2022, 02:01:38 PM »
All packed up and ready to go Clive.
Martyn I've got your address, I'll PM you PayPal details.
I now have 8 left.
« Reply #8 on: September 17, 2022, 05:14:03 PM »
Just 5 left. I kept 3 for my own use but I only really need 1 so if push comes to shove I can sell 7.
I have sourced some NOS thumb screws and springs, Roo kindly let me have them sent to him whilst he's in the States as the postage was exorbitant for such a small part, about £20 IIRC, how they justify that I have no idea.
I have 6 springs and 2 thumb screws available, I'll need to work out a price when the final bill is tallied but they won't be available until November when Roo comes back.
Managed to source 2 more thumb screws, so now have 4 available.
« Last Edit: September 17, 2022, 08:44:27 PM by Oddjob »
« Reply #9 on: September 17, 2022, 10:06:59 PM »
Ken, I’ll have a ramp thingy, definitely missing one. Have spring and screw fitted already. I’ll sort payment.
1978 Honda CB550K3.
« Reply #10 on: September 17, 2022, 10:28:14 PM »
Payment received John, will be in the post Tuesday due to bank holiday
« Reply #11 on: September 24, 2022, 07:36:16 AM »
Recieved throttle ramp thingy yesterday Ken! Thanks again!
1978 Honda CB550K3.
« Reply #12 on: October 28, 2022, 07:12:02 PM »
I have managed to acquire via Roo a number of genuine Honda thumb screws and springs that go with the ramps. I have 6 pairs of springs and thumb screws.
I'm trying to work out the cost of these at the moment but around £18 inc P&P for a pair is a rough guide. If you want a ramp along with it then £23 inc P&P
« Reply #13 on: October 28, 2022, 07:13:38 PM »
I need a screw & spring please.
« Reply #14 on: October 28, 2022, 07:15:10 PM »
Yeah, already had one ear marked for you Ted.
You drilled and tapped the switch gear yet?
