Author Topic: Points Cover Oil Leak  (Read 757 times)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« on: September 20, 2022, 10:07:49 AM »
I have a considerable leak from my points cover - CB750 K2/4.
Having read related posts it seems the issue is either the crankshaft seal or the o-ring on the advancer shaft or both.
O-ring replacement is relatively easy, but there is debate as to whether the seal, which has an outer lip, can be replaced without splitting the cases.
Now FASTURD posted on the US site on his similar experience a while back and concluded with this:
http://forums.sohc4.net/index.php/topic,71635.msg868522.html#msg868522 - Go down to post No 22.
Having just replaced the head gasket, I do not want to take the engine out again, so I am going to  try to check where the leak is coming from and then if necessary try to replace the seal with a non-lipped one as described above.
I can get a seal with the correct dimensions, one single-lipped and the other with two lips - internal I think. The second lip is I believe a dust seal.
https://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=1&keywords1=30&keywords2=42&keywords3=8&
Does it matter which one I use and if so which one should I go for?
CB750 K2 - Ridden from Belfast(SA)-2-Belfast(NI)!
CB450 K1 - A work in progress.
Re: Points Cover Oil Leak
« Reply #1 on: September 20, 2022, 10:16:22 AM »
If it was me I would go for the double lip if it's no thicker in depth.
Others here will have an experienced view.
Offline Skoti
« Reply #2 on: September 20, 2022, 10:54:01 AM »
I think it's an engine out and split the cases job to renew that oil seal.
I'm sure the oil seal has outer ridge that locates into grooves on the cases, but somebody else will be along shortly to confirm or correct me on that.
But you won't have to touch the top end to change that seal, just pull off the side casings and remove all the gubbins, then turn the engine upside down and spilt the cases, remove the cam chain tensioner so you can ease the crank up a bit to remove the seal.
Any way good luck with that.
Skoti
1976 Honda CB750F1
« Reply #3 on: September 20, 2022, 11:56:44 AM »
Some time ago (at least a year or two) we discussed exactly this but can't find the thread immediately.
After much debate, the upshot was that it wasn't that difficult to change it successfully in situ from what I recall. Memory says it was someone in Australia that was doing it or referenced something from there.
More searching may find it, obviously  ;D but I can't with logical search phrases seem to locate it.
« Reply #4 on: September 20, 2022, 12:34:39 PM »
Skoti
I think that is only the case if you use an original seal the link appears to show a replacement that worked without splitting the crankcases.
« Last Edit: September 20, 2022, 01:09:27 PM by McCabe-Thiele (Ted) »
« Reply #5 on: September 20, 2022, 12:59:53 PM »
Worth checking the engine breather arrangements too, we've had scenario on here when the breathers weren't breathing (connected round in a loop so effectively pressured engine/cases) that pushed oil out through the seals generally.
« Reply #6 on: September 20, 2022, 01:21:10 PM »
Found this, more info but no instant cure
http://forums.sohc4.net/index.php?topic=5118.0
Den
« Reply #7 on: September 20, 2022, 01:49:25 PM »
Firstly you must find what and were it is leaking. Clean the area with brake cleaner, dust it with talcum powder and you will see were the oil first appears.
The shaft can be a bugger sometimes to get out after 50 years. I have always found it is a 50/50 on whether it will move or just snap in the crank. I have had some so stuck that, i have removed the crank, had the shaft in a vice with a ton of heat until it moved.  :o
