Author Topic: Carb balancing - stupid question ......  (Read 917 times)
Offline SPR
  • 1972 500/4 K1
« on: September 21, 2022, 05:24:02 AM »
Morning
Before I balance the carbs ... a question about connecting an auxillary fuel tank.
The 500 has two fuel pipes whereas the 550 had one .. do i need to feed fuel to both pipes using some sort of Y connector ?
Yes I know - basic question :)
Simon
Re: Carb balancing - stupid question ......
« Reply #1 on: September 21, 2022, 05:39:28 AM »
Yes, I use a Y piece. The 550 has a Y piece down stream of the tap
Offline SPR
  • 1972 500/4 K1
« Reply #2 on: September 21, 2022, 05:41:51 AM »
Brilliant - thanks ... I'll get one ordered
Simon
« Reply #3 on: September 21, 2022, 10:01:19 AM »
Bearing in mind the flamability of petrol does anyone make a safe auxilliary fuel tank at a sensible price?
Any links or tipe welcome - something like this?
.https://www.ebay.co.uk/itm/314084385274
« Last Edit: September 21, 2022, 10:05:08 AM by McCabe-Thiele (Ted) »
« Reply #4 on: September 21, 2022, 10:09:09 AM »
I use the 20.99 one featured at the bottom of the page.
« Reply #5 on: September 21, 2022, 10:18:53 AM »
I've used a couple of Sealey MS209's for years, and they're a decent bit of kit. Nice thing with this is you can extend the supply pipe slightly and hang the tank higher give the carbs a bit more 'static head' - good for making sure the float needles are definitely seated and not leaking...
https://www.ebay.co.uk/itm/191412318383
« Last Edit: September 21, 2022, 10:20:35 AM by JamesH »
Offline ST1100
« Reply #6 on: September 21, 2022, 11:41:06 AM »
STOC #637
« Reply #7 on: September 21, 2022, 01:24:36 PM »
I gather then James you use 2 reservoirs to feed the twin pipes instead of using a Y splitter?
« Reply #8 on: September 21, 2022, 04:30:41 PM »
Why not strap the tank to the buddyseat and use extension tubes? You have to remove the tank anyway.
Offline SPR
  • 1972 500/4 K1
« Reply #9 on: September 21, 2022, 08:13:09 PM »
Knowing my luck I'd drop it !!!
Cheers everyone .... plan sorted so will hopefully get on it at the weekend
Simon
« Reply #10 on: September 21, 2022, 08:33:21 PM »
For longer than I care to remember I've just stuck a plastic medical syringe of about 150ml into the existing feed pipes/s held vertical by stiff wire to nearest frame point.
Fill with fuel and that's enough to run for easily enough setup time.
« Reply #11 on: September 22, 2022, 12:24:14 PM »
Lol - I lost one for a while, bought a replacement, then found the orginal.
