Author Topic: What lights should be on in 'P' Switch position?  (Read 1329 times)
Offline scrubs
« on: June 19, 2010, 07:31:59 PM »
My 1974 CB750 just failed its MOT numerous reasons, nothing happened when the right hand switch gear was set
to the 'P' position. I am under the assumption and as far as I'm aware it is a UK bike not US import,
should I have a seperate little parking light bulb in the headlight shell that turns on with the rear light
when set to 'P'?
I posted this question over on the US site http://forums.sohc4.net/index.php?topic=72708.0
Got a mixed response - but don't really have a clear idea yet, so thought I'd check here too.
Re: What lights should be on in 'P' Switch position?
« Reply #1 on: June 19, 2010, 08:25:17 PM »
Yes.
To pass the MOT, all fitted lights must work.
The P position is for "park" and should light the little (5W?) bulb in the headlamp as well as the rear light.
2022 Tiger Sport 660
Offline scrubs
« Reply #2 on: June 19, 2010, 08:35:54 PM »
Thanks for clearing that up Steve, Just need to check the lamp I have has the hole for the small 5w bulb now.....
hopefully will be on the road again soon, the other fails were tiny just some loose bits that I didn't tighten properly
in a hurry..
Offline scrubs
« Reply #3 on: June 19, 2010, 08:37:05 PM »
oh by the way.. If someone has a right hand switch gear for sale or knows where I can get one for this model,
please let me know.  ;)
Offline daz
« Reply #4 on: June 20, 2010, 03:54:40 PM »
P position on my  bikes with ignition on, is pilot light also known as side light & H position is the main headlght, cheers Daz.
http://www.motuk.com/bike/1-1.asp
« Last Edit: June 20, 2010, 04:01:59 PM by daz »
Honda CB 550K0 1974,  Honda CB500X 2020
