Author Topic: Sudden engine cut outs  (Read 1841 times)
Offline Athame57
    • SeaWitch Artist
« on: October 26, 2022, 02:05:23 PM »
About four times in a couple of weeks now I've been riding along and engine stops. I coast to a near stop, go into neutral and hit start button engine fires up again. Fuel starvation I would rule out and probably electrical as well (?) any ideas?
1978 CB400F2 called Elen.
Offline SteveW
Re: Sudden engine cut outs
« Reply #1 on: October 26, 2022, 02:22:14 PM »
Check the fuses, mine did this.
Fuses looked intact but when you removed  them from the fuse holder the ends just fell off.
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #2 on: October 26, 2022, 02:48:52 PM »
Well it's one or the other!
I'd start with fuses and check all the connectors attributed to the ignition circuit and clean before putting back together. Make sure everythings connected and making contact. Either that or the neutral switch, side stand switch if it has one or the clutch switch, again, if it has one. That would be where I would look first.
Even if you have it ticking over and wiggle everything and try to reproduce the fault, simple fix and cheapest way to start for me.
« Reply #3 on: October 26, 2022, 03:01:07 PM »
Definitely check the fuse George. The metal caps can vibrate and come loose, so they still have contact but not all the time.
« Reply #4 on: October 26, 2022, 03:10:49 PM »
My guess is ignition switch or connector too it
« Reply #5 on: October 26, 2022, 03:56:10 PM »
Have you replaced the fuse box? - my DS aftermarket one failed when fitted -wires not soldered on properly at the back on the ignition circuit.
Offline SteveW
« Reply #6 on: October 26, 2022, 03:57:12 PM »
Dodgy kill switch?
1974 CB550 K0
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline Athame57
    • SeaWitch Artist
« Reply #7 on: October 26, 2022, 04:47:06 PM »
I've checked a few things like my battery leads and fuses, I couldn't really find anything wrong but I changed some fuses anyway. I did find a few snails taking refuge under my panels though..... I'm not sure what to think of that!  :o
« Reply #8 on: October 26, 2022, 05:17:50 PM »
No ring of Table Salt around your bike for snail protection!
Offline Cappodimonte
  • Shoot first, less questions to be asked ☠️
« Reply #9 on: October 26, 2022, 07:37:28 PM »
Sudden stop failure points to electrical issue not fuel, that’s usually a stutter or misfire. Best to start with battery and it’s connections especially the earth strap to the frame, it could be as simple as it has loosened a little and/or rusted at the frame.
« Reply #10 on: October 26, 2022, 07:47:56 PM »
Need more info, does the engine stops but the lights etc stay on? Just an engine stop could mean the kill switch contacts, full shut down is most likely an ignition switch fault
« Reply #11 on: October 26, 2022, 09:33:25 PM »
Just a thought but, how long has the battery been on the bike ? Is it an old lead/acid or new gel type
If it’s been in situ for a fair while and is lead/acid it could be a battery plate has part failed and vibration causes a separation, short and immediate stop. The other fail points are kill switch or ignition switch, check ALL connections however and clean them up, electricity can build up resistance at rusted or corroded connection points
If it’s a gel battery then get it professionally checked out, anything electrical can fail anytime, these things can really wind you up.
Offline Athame57
    • SeaWitch Artist
« Reply #12 on: November 02, 2022, 05:00:56 PM »
I put the current battery in four years ago, it looks alright but I've never had a bike so long as this, I'll change it. I see on DSS the battery they offer for the CB400F is a gel type now, anyone experienced this offering of theirs yet? Now and then the starter button doesn't respond, usually first push of the day, by moving the kill switch and pressing....then putting it back and pressing it works again. I've opened it up but can't see anything wrong as meets the eye though. Maybe try some WD40?
« Last Edit: November 02, 2022, 05:03:34 PM by Athame57 »
« Reply #13 on: November 02, 2022, 05:08:19 PM »
Sounds like thats the culprit. Clean it towithin an inch if its life and re test then move down the wires. Cheap and easy.
Offline 400 Cafe Racer
« Reply #14 on: November 02, 2022, 06:03:12 PM »
Failing all else, as a belt and braces solution, you could wire a "Secret Hidden " bye pass switch, concealed from view. Wired direct from the battery - through its own seperate fuse - and connected to the ignition switch output wire.  This would enable you to get home without being stranded.  If the Ignition switch or fuse or anything on the live side fails you would be covered. :)
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest    - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
