Author Topic: 400/4 Carb bits  (Read 1000 times)
Offline Matt_Harrington
400/4 Carb bits
« on: November 13, 2022, 02:09:52 PM »
Mmm, I seen to have lost the following:
1. 2 off nuts from the choke control rods (slim M7)
2. 2 off caps that are on the same shaft that retain the felt washers.
Anyone got those parts they want to part with?
Re: 400/4 Carb bits
« Reply #1 on: November 13, 2022, 03:29:03 PM »
I will have a look on my junk carbs for you but not till later in the week as its my dearly beloveds birthday tommorow
Re: 400/4 Carb bits
« Reply #2 on: November 13, 2022, 04:26:16 PM »
SWMBO always comes first!!  ;)
Re: 400/4 Carb bits
« Reply #3 on: November 13, 2022, 06:08:27 PM »
Bryan, don't worry about the nuts - I've made the half nuts. I'll try and turn up the flanged washers tomorrow but if you find a couple of originals.....
Re: 400/4 Carb bits
« Reply #4 on: November 13, 2022, 07:50:04 PM »
I think they are plastic from memory
Re: 400/4 Carb bits
« Reply #5 on: November 14, 2022, 09:50:46 AM »
Nope, small metal ones which retain the felt washers on the choke shafts (either side).
Comme ca:
It is the washer either side of the felt washers and is a light press fit into the carb body.....
Re: 400/4 Carb bits
« Reply #6 on: November 14, 2022, 09:52:58 AM »
Mind you, Bryan, That is a good idea! - I could turn up some solid nylon ones if needs be - much simpler.....
Re: 400/4 Carb bits
« Reply #7 on: November 14, 2022, 10:59:59 AM »
Im sure i remember top hat plastic ones but that could be a different model as i have several 500 sets and only one partial 400 set
Re: 400/4 Carb bits
« Reply #8 on: November 14, 2022, 01:07:15 PM »
You're thinking of the 500 Bryan, has plastic top hats on the throttle lifter arm.
Kept thinking of what Matt was referring to but seeing the pic has refreshed my memory. I'd go with plastic ones Matt, they are only dust seals after all.
Re: 400/4 Carb bits
« Reply #9 on: November 14, 2022, 07:05:29 PM »
Yes, I like the idea of plastic ones - off to the workshop tomorrow.....
amx1992
Re: 400/4 Carb bits
« Reply #10 on: November 14, 2022, 09:58:12 PM »
Ive got some spare if you want a pair
Re: 400/4 Carb bits
« Reply #11 on: November 14, 2022, 11:43:26 PM »
It would save me some effort!!
Re: 400/4 Carb bits
« Reply #12 on: November 16, 2022, 03:35:25 PM »
Got into garage today, can easily get the nuts, lockwashers and operating arms. Washers means i have to remove choke buterflies which i dont really want to do.
The plastic top hat washers i was thinking of are on the throttle shafts
Re: 400/4 Carb bits
« Reply #13 on: November 16, 2022, 03:41:44 PM »
Bryan, Thanks for looking. Max has sorted the cup washers and I have made the M7 half nuts, so I think I'm sorted. Yes - don't dismantle the carbs. The only bit I need to make is the end one on N04  - this is a blanking plug and can be easily made from brass and secured in place.
Re: 400/4 Carb bits
« Reply #14 on: November 16, 2022, 04:21:56 PM »
No problem, if anybody needs 400 carb bits these are there but no adjuster bits as they went on comfysofas carbs
