Author Topic: 1977 GL 1000K2 COILS  (Read 2218 times)
Offline Moorey
« on: November 30, 2022, 07:32:36 PM »
    Can anyone tell me how many ohms the primaries are on just the coil for a 1977 GL 1000k2 are. The coil is a tec FL101  part# 30502371003
    I seem to be getting a lot of conflicting info.
Re: 1977 GL 1000K2 COILS
« Reply #1 on: November 30, 2022, 10:45:54 PM »
I am at work till 6am but will check my genuine book for you tomorrow
Offline Moorey
« Reply #2 on: December 01, 2022, 09:33:31 AM »
   Cheers Bryan.
« Reply #3 on: December 01, 2022, 12:02:38 PM »
Assuming it's not a CDi ignition I think GL1000 Goldwings had a coil combined with a ballast resistor. So expect a much lower primary resistance than the standard  'Honda-4" coils. From memory it should be around 2.7 Ohms and the ballast resistor about the same. But Bryan's manual will hopefully confirm this. All I am really saying is that if you encounter a low resistance reading (around half of the 4-5 Ohms for a Honda 4 coil) then don't worry, chances are it's OK.
Offline Moorey
« Reply #4 on: December 01, 2022, 01:57:11 PM »
  All I seem to be able to find in the manual is test it in the coil tester. Ballast resistor 3ohms.   I just seem to be finding lots of contradicting info and coils listed from 2 t0 5 0hms listed for the GL1000.
 I am trying to find out for someone else. Thanks for your input Ash.
« Reply #5 on: December 01, 2022, 08:22:22 PM »
My book wasnt where i thought it was, i have abother at a mates house so can get the info sat
« Reply #6 on: December 01, 2022, 08:37:58 PM »
Sorry, quick-high jack, sorry!
Bryan, did you get a chance to measure up that suzuki mudguard mate? I'm not pestering as I guess you're dead buy leading up to Crimbo etc? More of a reminder if you get a sec. Thanks again mate, you're a good un.
Sorry, carry on,................Coil info coming on saturday etc..... ;) :)
« Reply #7 on: December 03, 2022, 01:38:25 PM »
Roo, not had time yet, going norf to visit fambly mate.
The only book i have access to at moment is GL 1200 which is electronic and that says 2.3 to 3.0 ohms, i will continue looking for the 1000 book
« Reply #8 on: December 03, 2022, 02:59:51 PM »
If it helps the overview for OP,  electronic equipped makes use of low ohm rating because they can control the switched on time, dwell, on a fixed time basis and irrespective of engine rpm.
Points based systems have dwell in angles of crank but with it changing/shortening as revs rise on time basis. Too low ohm rating leaves the coils on too long during low rpm if they are paired.
Low ohms rating on points may overheat coils in drawing too much from supply at low rpm. High ohms on electronic may give high rpm compromise as it remains not fully saturated when supply is terminated to fire plugs.
« Reply #9 on: December 03, 2022, 05:22:18 PM »
Big problem with the 1000 was they had 9v ballasted coils to get better spark for starting, like 70' fords and vauxhalls
Offline Moorey
« Reply #10 on: December 05, 2022, 03:56:15 PM »
    The bike is still on the points system.
Offline Moorey
« Reply #11 on: December 05, 2022, 04:03:09 PM »
   The ballast resistor is within spec Bryan.  I have asked the same question on a couple of Wing forums and a Wing FB page but no responses on the
    actual coil readings
« Reply #12 on: December 05, 2022, 05:03:03 PM »
It is so rare for coils to fail electrcaly that i cant remember a set! the wires do get old but Ash'fix cures that.
« Reply #13 on: December 05, 2022, 06:02:55 PM »
Would the information so far on here suggest that the coil will be  9v /2ohm making a running system of coil plus ballast switched by points at combined nominal 5ohm in continuous state?
Then that would produce 12v (over capacity) 2ohm "hot" coil via supply route when starting as it's usual to temporarily eliminate the ballast resistor through start switching to enhance immediate firing.
Offline heli_madken
« Reply #14 on: December 05, 2022, 06:34:22 PM »
I was really unlucky my original K2 was just over a year old back in 1979 when both coils suddenly failed leaving me stranded, so it can happen.
On my current K2 I went to a Dyna electronic system with Dyna 3 ohm coils and bypassed the ballast resistor. Been in place for 4 years and never missed a beat.
