Author Topic: Yellow (Size D) Main Bearings  (Read 651 times)
Offline Rogerxlixi
« on: January 31, 2023, 01:44:09 PM »
Hi All,
Just in process of an engine rebuilt and have worked out what main bearings i need. Namely 6 yellows and 4 greens. The greens look to be in good supply, but can't say the same for the yellows. David silvers and CMSNL both out of stock, found another site over in japan but still nothing.
Does anyone have any leads on yellow bearings at all?
Any other solutions out there at all?
Toying with the idea of trying a green out and seeing how the clearance is with plastigauge.
Re: Yellow (Size D) Main Bearings
« Reply #1 on: January 31, 2023, 02:03:57 PM »
Unless the crank is new, the journals will be worn and you should be able to upsize to green  ;)
Offline Rogerxlixi
« Reply #2 on: February 01, 2023, 11:15:07 AM »
Thanks for that trigger, appreciate it.
Having finally found a battery for my Vernier the crank journals do measure up slightly worn and a smidge below the 32mm nominal. Will be getting greens all round.
« Reply #3 on: February 01, 2023, 12:45:49 PM »
You can not measure with a Vernier, you need a micrometer that can measure correctly and precise  ;)
Online McCabe-Thiele (Ted)
« Reply #4 on: February 01, 2023, 02:41:27 PM »
And a decent micrometer as well.
« Reply #5 on: February 01, 2023, 05:03:34 PM »
Just go up a size and fit greens if the crank looks ok.
Offline 400 Cafe Racer
« Reply #6 on: February 03, 2023, 05:16:12 PM »
Rogerxlixi
As well as physical instrument measuring, you should be able to get a final accurate clearance reading confirmed by assembling the bearing with "Plastiguage", then  torqing to correct setting, then disassemble to read the actual clearance for each journal. Its a bit time consuming but gives a clear result IMHO.
Dennis :)
« Last Edit: February 03, 2023, 05:18:59 PM by 400 Cafe Racer »
Retired Automotive Engineer   MIMI, MITRE, DMS, MCMI.
Latest    - 1979 CB400/4  Cafe Racer - Parakeet Yellow
              - 1939 Velocette GTP 250 twin port Two stroke
1988-91 - Lamborghini Countach QV replica design and
                 build - 3000hr spare time project
In 1956 at 12yrs old and dirt tracking
              - 1937 Rudge 500 4 valve
              - 1940s Royal Enfield 225sv
              -  Ex WD Norton 500sv
« Reply #7 on: February 03, 2023, 08:55:47 PM »
I agree with Dennis it's fiddly but Plastigauge works - I practiced on the con rods as it's simpler - then did the mains.
I will do the same on my 500.
