Author Topic: Got a prob with shafts pistons cams cranks etc etc  (Read 1853 times)
rigwit
« on: July 08, 2010, 10:22:54 PM »
Hindel reman of bradford are engine specialists  can make any size of plain bearing  -----  reclaim worn shafts--  got a crank that is out of hondas limit---- no problem for them they submerge weld the journals and then grind to whatever spec you need-same with cams and lobes-------  ive had dealings with them in the past regarding a cam you couldnt get anymore  and they did it no prob--  if they dont have the profile for it --it would help if it was given......  always  a way to keep the old stuff a going  direct link to reman service's
http://www.hindlereman.com/index.php?option=com_content&view=article&id=8&Itemid=3
« Last Edit: July 08, 2010, 10:29:17 PM by rigwit »
Offline pae
    • Phil's CB650 pages
Re: Got a prob with shafts pistons cams cranks etc etc
« Reply #1 on: July 09, 2010, 08:58:41 AM »
That's an impressive set-up. Worth keeping their name for the future, thanks for the link.
Offline Rozabikes Tim
« Reply #2 on: July 09, 2010, 10:14:18 AM »
S.E.P. at Kegworth, Liecestershire - just off J23 M1 do similar. I had crank done on a 400 superdream years ago. Think I have seen an ad recently in Classic Mechanics or Classic Bike.
Tim
