Nick Ive buckets of the right barrel connectors for that set up if you havent got any and before you reach foir the nasty blue ended lumpy things
Giz a bell when you're in, fed and watered and we can have a yap, need to run some bits passed you, when 20 questions, yer know. Re yer chopper.................yer 750 that is
Cheers mate, I'm sorted for good connectors, need some 10amp yellow wire and some heat shield tho
Not sure how far back into the coils I can go to solder nice fresh wire and connectors up and out of the cover.. will see when I take the alt off I guess
