Author Topic: Carb float levels  (Read 2635 times)
Re: Carb float levels
« Reply #45 on: July 11, 2023, 08:59:56 AM »
In my case they did. Here's the variety I've tried. All resulted in issues. Basically there are two problems a float valve can have. A needle that's sticking in the valve. Tapping can help. Also a fuel system cleaner additive can help. A needle not perfectly shutting the valve is the other problem. A tiny particle of dirt can cause this. Again: tapping and flushing by opening the drainscrew and opening and closing the petcock. With the OEM fuel filter in good order, there's no need for any extra filtering.
Offline davidcumbria
« Reply #46 on: July 11, 2023, 09:14:47 AM »
By oem fuel filter I assume you mean the filter on the fuel tap inlet inside the tank ?
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
« Reply #47 on: July 11, 2023, 02:58:47 PM »
Yes.
