Author Topic: Rubber Mounting Rubbers - 84705-292-000  (Read 1208 times)
Re: Rubber Mounting Rubbers - 84705-292-000
« Reply #15 on: April 24, 2023, 07:50:46 PM »
I don't think those fairing ones fit Roo iirc they are too small.
Pretty sure I bought some for my 400 a couple of years ago - could be mistaken holes are 6mm?
According to the pictures the metal insert internal hole is quoted as 6mm Ted
« Reply #16 on: April 24, 2023, 07:59:59 PM »
As they were cheap I bought them - I'm sure they did not fit. Can't check as my e- bay history does not go back that far.
Might have been different ones - they were for fitting fairings. No idea where I put them - might be in my loft with my 400 left overs.
Might have been the battery box not the number plate ones. Still nagging me they were wrong - might have been a different listing.
I've been to bed a few times since 2020 when I bought them so my memory is not to be relied on.
« Last Edit: April 24, 2023, 10:55:32 PM by McCabe-Thiele (Ted) »
« Reply #17 on: April 24, 2023, 08:00:32 PM »
The pictures in the advert quote a 6mm internal metal insert dimension Ted so assume with a 1mm wall to the insert, that the internal rubber dimension is 8mm ish
« Reply #18 on: April 24, 2023, 08:15:27 PM »
I'd say you are correct Phil, the 6mm hole is the bolt hole on the metal dowel, that usually means the internal hole in the rubber is 8mm.
They aren't as wide as the originals though. 10.8mm as opposed to 13mm, that's only around 1mm smaller each edge.
« Reply #19 on: April 24, 2023, 09:12:26 PM »
At the end of the day if they work the numpty who measures them and tells me they are 1/2 mm wrong sized gets my size 10 steel toecap somewhere uncompfortable, just before i bin them!
« Reply #20 on: April 24, 2023, 09:25:22 PM »
I'll have a go using those suggested by Bryan and then you've still got spare ones Ken - thanks
Sent from my moto g(50) using Tapatalk
