Author Topic: Points cable clips (cramper!)  (Read 634 times)
Offline Matt_Harrington
« on: May 15, 2023, 10:22:27 AM »
I'm missing the cable clips for my points cable. Anyone got the pair (to sell) that go on the engine OR an outline of them so I can fabricate a couple?
I think the parts used to be: 32117-371-000 & 32112-333-000
Re: Points cable clips (cramper!)
« Reply #1 on: May 15, 2023, 11:23:22 AM »
Got a piccy Matt, cant find any images on line and I might have something in my  parts drawers that came off during the strip down......
« Reply #2 on: May 15, 2023, 11:48:42 AM »
The one near to the points cover is different but this is the one further up. I haven't got a picture of the other  :'(
« Reply #3 on: May 15, 2023, 12:18:27 PM »
And this, I think is the other clip....
Online McCabe-Thiele (Ted)
« Last Edit: May 15, 2023, 12:43:49 PM by McCabe-Thiele (Ted) »
« Reply #5 on: May 15, 2023, 01:20:48 PM »
Try looking at 32111323000
They have a plastic coating to protect cable.
Should be available from any Honda dealer but about £4 each
« Reply #6 on: May 15, 2023, 02:51:25 PM »
Matt I just cut some from some galv sheet, prepped and painted them and bobbed a bit of shrink tube over the top to protect the wire. Cost pence and you can’t tell the difference unless you were looking out for it…..
« Reply #7 on: May 15, 2023, 02:58:16 PM »
Roo, that is what I was thinking of. However, you know me and the stainless sheet will be coming out!!  ;)
Just realised that there maybe the clips on the engine from Tim, will look a bit later.....
« Reply #8 on: May 15, 2023, 03:00:44 PM »
That’s a good shout…..I’m sure there’ll be some to poach off that…..
I didn’t have any stainless and only galv guttering that I cut up
Works a treat
Offline sye
« Reply #9 on: May 15, 2023, 03:03:15 PM »
Rubber lined stainless P-clips?
« Reply #10 on: May 15, 2023, 03:05:38 PM »
No there like a flat tang which the bolt goes through and then you bend to suit over the cable.
« Reply #11 on: May 15, 2023, 04:39:37 PM »
I'm making some out of a sheet of stainless steel, cut to shape, round the ends off after punching the 6mm hole through then using some glue lined shrink wrap tubing to line the steel. I made one the other day for a fuel pipe clip on a bank of carbs, turned out rather well considering it was a first attempt.
