Author Topic: What is this tool in our toolbag for?  (Read 3053 times)
« on: May 20, 2023, 07:29:02 AM »
Partslist says: BAR B, HANDLE. PN: 99005-02000. What is it for? Is that 'B' maybe a misread '8' in an older document? Width is 8mm.
Re: What is this tool in our toolbag for?
« Reply #1 on: May 20, 2023, 07:38:22 AM »
Maybe spoke key .
Offline Matt_Harrington
« Reply #2 on: May 20, 2023, 09:04:38 AM »
A tuning fork?
« Reply #3 on: May 20, 2023, 09:07:41 AM »
There has been much discussion about that tool from tappet adjuster(too big) to spoke nipple key(bad fit) but basically its a tee bar for the plug socket
« Reply #4 on: May 20, 2023, 09:21:11 AM »
If it is 8mm, then there are quite a few things it can fit as well....
« Reply #5 on: May 20, 2023, 10:10:25 AM »
There has been much discussion about that tool...
I vaguely remember the discussion in the international forum and also that there was no definitive answer.
[...] from tappet adjuster(too big) to spoke nipple key(bad fit) but basically its a tee bar for the plug socket
Nope, it's too big for the holes in my OEM plug socket.
Question: did early CB500 models ever come with a brake bleeder 8mm head instead of the 7mm on ours?
Offline Seabeowner
« Reply #6 on: May 20, 2023, 07:04:12 PM »
My CB500s need one, my 550F1 needs one, my 1978 550K does not.     ?????
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline Moorey
« Reply #7 on: May 20, 2023, 08:13:00 PM »
 Well whatever it is it must be very important as it is still put in some Honda tool kits. Its in nearly 500 different kits including quads.  ;D
Offline Charliecharlcomb
« Reply #8 on: May 23, 2023, 10:28:59 AM »
What a wonderful question. I've often wondered the same. I doubt it's in there as a T for the plug socket, I always use the screwdriver attachment.
« Reply #9 on: May 23, 2023, 11:24:32 AM »
Old Triumph toolkits have a tool almost exactly the same which is for tappet adjustment.  It also has a tyre lever with a square cutout on one end which is for the wheel spokes.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #10 on: May 23, 2023, 12:53:18 PM »
Obviously a plug socket bar, with 8mm jaws added on - probably to adjust the throttle cable adjuster barrel which is about the only 8mm piece on the bike. (talking CB750 in this case)
« Reply #11 on: May 23, 2023, 02:59:08 PM »
Again... it's bigger than the holes in the plug socket.
Offline nikxan1
« Reply #12 on: June 18, 2023, 11:44:30 AM »
thats quite easy, its a spoke tool.
« Reply #13 on: June 18, 2023, 01:10:47 PM »
It's a tappet adjuster tool for a 400/4.
« Reply #14 on: June 20, 2023, 11:47:40 AM »
As far as the CB500/550s, there seems to be one place only where this tool fits perfectly and that is at the throttle cable adjusters.
