Author Topic: NGK plugs  (Read 1243 times)
Offline Pauarc
Re: NGK plugs
« Reply #15 on: May 30, 2023, 03:24:28 PM »
All plug set to 1-1/8 out on air screws going to try no1 out a bit more
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
Offline Martin6
Re: NGK plugs
« Reply #16 on: May 30, 2023, 03:58:46 PM »
Strange how they get slightly darker from 4 through to 1. 3 looks a bit damp?
Offline Pauarc
Re: NGK plugs
« Reply #17 on: May 30, 2023, 04:59:21 PM »
After a 30 mile run a bit better I think they are looking better now not sure if they may be a bit weak now?
Cb750k2
Re: NGK plugs
« Reply #18 on: May 30, 2023, 05:01:38 PM »
Not to weak at all
In fact I would lean the tickover even more,
Offline Martin6
Re: NGK plugs
« Reply #19 on: May 30, 2023, 11:00:24 PM »
Looking good. If it were me, I'd run like that for a few hundred miles and see how it goes.
Offline Pauarc
Re: NGK plugs
« Reply #20 on: May 31, 2023, 01:10:05 PM »
Turned no 1 out a little more now all same colour but the tic over uneven if set at 1000  not sure 🤔 what maybe the problem runs well otherwise
Cb750k2
Offline Martin6
Re: NGK plugs
« Reply #21 on: May 31, 2023, 08:46:51 PM »
TBH, i wouldn't worry about it at all at only 1,000rpm. Set it to 1200rpm and I'd expect it will run evenly. Mine's similar, but very smooth at 1200rpm. I expect so much has to be spot on to idle evenly at 950rpm, hugely unlikely to get it like that, 50 years on, without major work, new carbs pistons, chains, remove all wear in the valve train... etc. Better to tune it to be a good mix for running.
Offline Pauarc
Re: NGK plugs
« Reply #22 on: June 02, 2023, 10:09:35 AM »
Could this top seal be giving a vacuum leak as it’s damaged
Cb750k2
