Author Topic: Spindle clamps , fitting of.  (Read 375 times)
Offline Athame57
    • SeaWitch Artist
« on: June 11, 2023, 07:59:54 PM »
Is there a definite procedure for fitting the spindle clamps on that matters, I'm sure I saw something like this recently. I'm about to put a new second hand speedo snail on  ;)  major technological challenge!
1978 CB400F2 called Elen.
Re: Spindle clamps , fitting of.
« Reply #1 on: June 11, 2023, 08:26:34 PM »
Arrow on the clamp pointing forward or the F mark, depends on which one you have. If no mark put the clamp on a flat surface and press down, one end won't be level, that's the back. Fit and tighten the front nut up completely so there is no gap and then tighten the back nut up. That's it
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: June 11, 2023, 08:52:15 PM »
Thanks for this Oddjob. I wonder if they are on properly even now? I'll see in the morning.  ;)
« Last Edit: June 11, 2023, 08:54:10 PM by Athame57 »
