Author Topic: 500 brake calliper  (Read 752 times)
Offline gary123
500 brake calliper
« on: June 17, 2023, 12:38:03 PM »
Does anyone have a front brake calliper for a cb 500. cosmetically challenged is ok as ill be painting it.
Just thought id ask before taking a chance on an ebay listing.
Re: 500 brake calliper
« Reply #1 on: June 17, 2023, 12:46:57 PM »
Go to amazon look up M Mati cb500 caliper, you get one complete with bracket, adjuster and pads for about £64 delivered
« Reply #2 on: June 17, 2023, 02:03:48 PM »
Product feedback is very poor even allowing for a few idiots.
« Reply #3 on: June 17, 2023, 02:17:07 PM »
3 bad reviews and one good one. Strangely the bads are all from the USA, one bought for a 750K6 and nowhere does it claim to be suitable for that model, the 750 uses a different caliper.
The worst one claims the piston is a one piece affair as standard, it isn't, it's hollow but has a cap fitted, ok the o-ring is split, not good, but for the price I think they are fine. Saying that I've bought one but not fitted it yet, I must inspect it to make sure none of the things they are reporting are on mine. As for the thread being wrong for the solid pipe, fitted a CB400 and that has the same solid pipe as the 500/550 so maybe it's his pipe that's wrong, maybe another 750 owner.
« Reply #4 on: June 17, 2023, 02:32:34 PM »
I can't find a single UK review be it good or bad - if it looks too good to be true...................
Be interesting to see an honest review from a sohc member who has fitted one.
Offline gary123
« Reply #5 on: June 17, 2023, 02:44:50 PM »
Yeah, reviews are not great, but for that price I might take a chance. Its amazon so returns/refunds shouldn't be a problem.
« Reply #6 on: June 17, 2023, 02:47:48 PM »
Be the first to review here Gary - parts made in China so could be good or bad,
Offline gary123
« Reply #7 on: June 17, 2023, 02:58:12 PM »
Ordered, so ill let you know. Thanks for the tip Bryan.
I went for the "full package" so if its all good Ill have a spare bracket should anyone need one.
« Reply #8 on: June 17, 2023, 03:17:30 PM »
Just dug mine out, the piston is hollow, no cap fitted, not a problem for me as I'm fitting stainless steel pistons anyway. The bolt holes are good. The seal was fine, in fact I must have fitted it with the piston as it's inside the caliper, will need to blow that out so I can replace the piston. The pipe thread looks fine on mine, tested it on a brand new solid pipe, genuine Honda and it fitted just fine. The only thing I couldn't do was tighten it down fully as I didn't have a spanner handy but it threaded down enough that there was very little play left in the pipe.
Offline gary123
« Reply #9 on: June 17, 2023, 03:42:25 PM »
Cheers Ken, good to know.  Lots of brake pistons are not capped and I have a decent spare anyway
