Author Topic: Feathering leading edges of brake pads  (Read 380 times)
Offline Athame57
    • SeaWitch Artist
« on: June 21, 2023, 10:03:19 PM »
I've been told the need to do this might be why my brakes are squealing again days after doing a copper grease treatment. I've certainly heard of this but google isn't bringing up the answers I need and nor has the search on here. Can someone gently explain how I should go about this and try not to laugh?  ;D
1978 CB400F2 called Elen.
Re: Feathering leading edges of brake pads
« Reply #1 on: June 21, 2023, 10:10:27 PM »
Certainly worked for me on my 550, just removed pads and filed a small chamfer around the edge of the both pads.
1978 Honda CB550K3.
« Reply #2 on: June 21, 2023, 10:13:16 PM »
Whenever I fit brake pads if they are not supplied with a chamfer on the leading edge I just use a wide hand file and cut an angle on the leading edge.
If you look at the wheel rotation the leading edge is the first contact side - the other side of the pad is the trailing edge. I usually just take off the corner so as to speak.
Modern pads typically look like this - with motorcycle pads being much smaller in area you only need to angle the leading edge by 2 or 3 mm at around 30 deg if the squeal returns after a few thousand miles  repeat.
.modern pad by Macabe Thiele, on Flickr
« Last Edit: June 21, 2023, 10:18:36 PM by McCabe-Thiele (Ted) »
Offline Athame57
    • SeaWitch Artist
« Reply #3 on: June 21, 2023, 10:17:58 PM »
Thanks guys, I thought it would be something like this but I couldn't say I knew!
