Author Topic: CB750K6 float height  (Read 386 times)
Offline Phil9886
« on: June 24, 2023, 05:45:40 PM »
Hi. I've seen a couple of different dimensions listed for CB750 float heights (maybe because they are different for different models). Can anyone let me know the correct height for the CB750K6? I will be measuring from the small ridge inside the channel for the bowl gasket to the top of the float just as the needle valve closes - correct? While I'm here - is 2 turns out for the air screw a good place to start? Many thanks. Phil
P
Re: CB750K6 float height
« Reply #1 on: June 24, 2023, 06:10:56 PM »
P
26mm from the lower part of the ridge, with the carbs standing up and start with one turn out  ;)
