Author Topic: Speedometer resetting knob  (Read 378 times)
Offline Athame57
    • SeaWitch Artist
« on: July 02, 2023, 04:52:07 PM »
I want to remove the Speedometer resetting knob if that is what one calls the thing you put your days mileage back to 0000 as I'm soon to paint the casing. However it won't just pull off, or at least I haven't managed to. Is it supposed to do that, I don't want to end up spraying the thing and it's grommet as well.
« Last Edit: July 02, 2023, 05:13:22 PM by Athame57 »
1978 CB400F2 called Elen.
Offline Matt_Harrington
Re: Speedometer resetting knob
« Reply #1 on: July 02, 2023, 05:57:49 PM »
The knob is pushed onto a splined aluminium shaft. This shaft, in turn, screws onto the internal mechanism via a left handed thread. You maybe able to unscrew the shaft. One of my shafts was corroded badly and so I ended up making a new one. If not, I've applied a small amount of heat to the knob (hair dryer) and it has come off it's splines....
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: July 02, 2023, 06:18:05 PM »
Thanks for this, I've had a try again to no avail. I think I'll just mask it off with lots of care, before I break something again!  ::)
