Author Topic: Powder Coaters in Derbyshire Area a word of caution.  (Read 6326 times)
« on: July 04, 2023, 09:46:30 AM »
A bit of an update about the two powder coater I have used locally.
1. For my 400 I used Langley Powder Coater - so far no issues with my frame after 2 years - the coating was a tad thicker than I would have liked but at the price the finish was excellent. Done during Covid -  cost £155.
2. For my 500 I used RPT Engineering near Alfreton - the finish was excellent at the time being nothing like as thick as on my 400.  cost £190.
Sadly the underside of the rear of the frame now has some corrosion breaking through - my plan atm is to apply some black Hammarite as the area is well hidden but I will know it is there.
Why did I change - primarily due to price as Langley Coater wanted me to get the frame specially dipped elsewhere before they would touch it as it had been previously coated 20 years or so ago.  Total cost was estimated at around £350 in total.
« Last Edit: July 04, 2023, 10:08:00 AM by McCabe-Thiele (Ted) »
Offline Matt_Harrington
Re: Powder Coaters in Derbyshire Area a word of caution.
« Reply #1 on: July 04, 2023, 10:42:32 AM »
Ted, most powder coaters don't apply any anti-corrosive paint to the metal before coating. I always try and get them to zinc chromate parts before coating. On my cars, I can easily tell which parts weren't treated!  ;)
« Reply #2 on: July 04, 2023, 04:18:21 PM »
A good powder coater wil blast the frame and apply the prime coat on the same day. Leaving a blasted frame overnight is enough time for a light dusting of corrosion to set in.
I have always used Microblast Services in Windsor, never had a problem with any of their work and they seal threads etc before powder coating. They blast and powder coat the same day. Turnaround time is two weeks.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Rozabikes Tim
« Reply #3 on: July 04, 2023, 04:53:54 PM »
Sorry to hear that you are having issues with the Alfreton lot Ted.  Feel a bit bad - I know I suggested them, although I knew nothing about them, just a possible route etc. Bit of a pisser, as spitting distance from our gaff if they were any good!
« Reply #4 on: July 04, 2023, 05:12:04 PM »
Not your fault Tim - the reality is I wanted somewhere local that would be convenient for taking the items plus Langley Powder Coaters were being funny about having the frame chemically stripped first by another firm as it had been powder coated previously.
Might be my experience is not typical - either way worth flagging up for local members.
My frame was badly chipped in several areas so a re-finish was essential. I also like to support local firms when appropriate. If I need to use a powder coaters again I would probably go back to Langley PC.
« Last Edit: July 04, 2023, 05:14:43 PM by McCabe-Thiele (Ted) »
« Reply #5 on: July 04, 2023, 05:36:38 PM »
Why would you need to have a frame chemically stripped? they just blast off the old paint, doesn't matter if it's powder or normal paint.
Offline Skoti
« Reply #6 on: July 04, 2023, 05:43:57 PM »
Why indeed?
I had a spare wheel carrier powder coated by a company that made an arse of it, anyhow I didn't pay them and took it else where to have it done properly.
Then was told it would have to be chemical dipped to remove the powder coating.
Skoti
1976 Honda CB750F1
« Reply #7 on: July 04, 2023, 05:54:48 PM »
I've had loads of parts done that had already been powder coated, never heard of that before. I'll ask my powder coater if they are talking out of their ass.
« Reply #8 on: July 04, 2023, 07:19:40 PM »
Just what they insisted upon when I talked to the call handler/ receptionist.
« Reply #9 on: July 04, 2023, 08:43:11 PM »
My 750 frame had to be done twice because there was a small mark in the back of the frame after powder coating which the powder coater pointed out. He said it was acid dipped to remove powder coating before re doing. Think it was a lot quicker than trying to blast off new powder coating.
1978 Honda CB550K3.
« Reply #10 on: July 05, 2023, 12:49:32 PM »
I have used LSN coatings in Castleford quite a few times and they always acid dip first as part of the process.
They are very reasonable price wise  ;D
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
Offline SteveW
« Reply #11 on: July 05, 2023, 04:13:01 PM »
How much do they charge to blast and powder coat a frame, looking to get my 550 done soon and they are pretty close to me.
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #12 on: July 05, 2023, 07:04:34 PM »
I thought that i did one of your frames ? Or was that someone else  ::)
« Reply #13 on: July 06, 2023, 08:36:22 AM »
You did the 750 frame  ;) I had all the others done at LSN Z650, 400/4, 550 K3, Z650 cafe.
Honda CB400 4
Honda CB750 UK K1
