Author Topic: Earth nuts in headlamp  (Read 492 times)
Offline Athame57
    • SeaWitch Artist
« on: July 11, 2023, 06:30:19 AM »
Are the earth nuts on both sides of the headlamp shell interior meant to have a single terminal like the one in the picture here, or have separate ends? I've seen both on the internet now, whatever mine are a bodge and one is rusty as hell so I want to replace, but which is it?  ( BTW...Earth nuts, that is what the Germans call peanuts!  ;D )
« Last Edit: July 11, 2023, 06:31:59 AM by Athame57 »
1978 CB400F2 called Elen.
Re: Earth nuts in headlamp
« Reply #1 on: July 11, 2023, 08:02:17 AM »
Both will work, maybe they were different for different countries. UK 400's were singles  ;)
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: July 11, 2023, 09:57:17 AM »
Like the one in the pic? It is actually on the 400Four website, but I havn't had an answer from him yet...........
« Reply #3 on: July 11, 2023, 10:09:09 AM »
My UK 400 had one earth nut on each side as does my 500 - my parts book also shows Qty 2.
IIRC each wire had a connector not two into one.
« Last Edit: July 11, 2023, 10:13:33 AM by McCabe-Thiele (Ted) »
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: July 11, 2023, 10:53:24 AM »
Yes, I just managed to find out myself, part 466 in this image from cmsl. Meanwhile my left front indicator has stopped working since I put the jungle back together. It seems the bodger of the past has left another fish under the floorboard for me.  ::)
« Reply #5 on: July 11, 2023, 11:56:26 AM »
In my limited experience poor earths inside the headlamp wiring are common.
FWIW I added a new earth wire on each indicator attached to the lamp end that meant threading two wires down the four stalks instead of just the lamp power feed.
My rear indicator earth on the bracket that goes to the frame was in very poor condition plus all that rubber mounting does not make earthing reliable.
It was a while ago now so can't remember where but I also added some extra earths for the frame & rear lamp wiring loom - they are out of sight so thought it was a good idea at the time.
« Reply #6 on: July 11, 2023, 12:30:11 PM »
Must admit to never seeing a linked pair like your pic, always seperate
