Author Topic: Kick start and clutch operation  (Read 1746 times)
Offline CB-500
Re: Kick start and clutch operation
« Reply #30 on: July 18, 2023, 07:22:24 PM »
I see what your saying - When turning the engine over at the crank you also have the aid of the crank throwing weight
But with the issue I’ve found do you reckon I’m looking down the rights lines?
Online McCabe-Thiele (Ted)
« Reply #31 on: July 18, 2023, 07:38:39 PM »
I'm a few months away from your level of assembly so am not able to offer a comparison.
Sorry to ask but is there any possibility you have the con rods the wrong way round ?
Offline Matt_Harrington
« Reply #32 on: July 19, 2023, 09:31:26 AM »
Ted, that is an interesting point you raise.....
« Reply #33 on: July 19, 2023, 09:38:20 AM »
Shouldnt make any difference to the engine rotating, if it rotates by hand it should rotate with kickstart
« Reply #34 on: July 19, 2023, 10:46:51 AM »
So with the clutch pressure plate, friction plates/discs and clutch centre hub removed this leaves just the clutch outer housing on the main shaft
Turn the engine over via the crank - this turns the primary drive gear clockwise which turns the clutch outer housing anti-clockwise
Being careful with two long screwdrivers I’m unable to turn just the outer clutch housing on its own the same way (anti-clockwise) in an effort to turn the engine over like the kick start would
Am I missing something?
Although the clutch outer is a big diameter it will be difficult to turn the engine over using it because of the gearing.
Looking at the clutch basket when trying to rotate the engine by hand you are trying to turn a large gear - think cycle front chainwheel to turn a much smaller gear in my head that should work.
If I grip that small bottom gear I can move my crank pretty easily.
Not got my block in place yet so can't try my basket.
« Last Edit: July 19, 2023, 10:59:46 AM by McCabe-Thiele (Ted) »
Offline CB-500
« Reply #35 on: July 20, 2023, 07:24:39 AM »
After quite a few google searches by accident I came across a few posts on the sister forum where people have experienced the exact same problem with their 500 kick start - they also had the problem after a rebuild or if the engine had been sat on the bench partially stripped/built for a extended time
One post explained that they also were convinced everything was assembled correctly and decided to forget about the kickstart and just continue with the project - They found once their project was up and running they randomly decided to re-look at the kick start issue - However the kick start was working with no explanation
I looked at my engine again - concluded that everything was assembled correctly - So with the clutch fully fitted started lightly jolting the kick start - after quite a while I noticed the primary gear drive started jolting along with the clutch - at the same time as jolting the kick start I started manually turning the engine over - after quite a few turns everything appeared to free up and the kick start is now working as it should
Offline davidcumbria
« Reply #36 on: July 20, 2023, 07:41:33 AM »
That’s good news. Sounds like the whole system has to rotate a few times to self align. Hard not to worry about these things when you’re not rebuilding engines every week!
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own  R1100GS, RD350LC YPVS , Triumph Street Triple, Yamaha XT250
« Reply #37 on: July 20, 2023, 08:53:45 AM »
That is weird.
I did wonder if lack of oil everywhere might be part of the issue hence why I kept on thinking friction in the bores was causing it.
Offline CB-500
« Reply #38 on: July 20, 2023, 09:22:03 AM »
If you go back to the kick start a while later it is again stuck - However it appears to free off easier each time
A mate of a mate who builds race/competition engines mentioned that the engine assembly lube I have used is fine for my normal engine build but can be known for causing slight drag on components during the build process - All should be good once up and running with normal engine oil circulating
Thanks everyone for your help on trying to resolve
« Reply #39 on: July 25, 2023, 05:18:04 PM »
Out of interest before I fitted my pistons I could rock the crank by hand using the bottom gear on the primary drive - now with the pistons in place - no chance. I put that down to the friction from the new pistons.
