Author Topic: Starter switch  (Read 1585 times)
Offline gary123
Starter switch
« on: July 22, 2023, 07:50:11 PM »
Im fitting a switch like this, only its an old genuine Honda one. Where does it get the earth from for the starter ?
There is a blob of solder on top of the switch inside which activates the solenoid when earthed but it doesn't touch the handlebars, should it or am I on the wrong track altogether? [ Guests cannot view attachments ]
Re: Starter switch
« Reply #1 on: July 22, 2023, 07:55:31 PM »
All the switch does is operate the solenoid/relay
The heavy current is carried by power lead to the relay,and then the starter.
Offline gary123
Re: Starter switch
« Reply #2 on: July 22, 2023, 08:10:58 PM »
Yes I understand that, my issue is the circuit diagram shows the switch creates a circuit by connecting the yellow/red wire to earth, but I dont have an earth conection.
Offline Arch stanton
Re: Starter switch
« Reply #3 on: July 22, 2023, 09:54:01 PM »
The starter button simply connects the yellow/red wire to the switch cluster body. Therefore making earthing it to the handlebars.
Offline gary123
Re: Starter switch
« Reply #4 on: July 22, 2023, 10:28:51 PM »
So it earths through the body of the switch. Mine doesn't so Im thinking something is missing from the inside.
Does anyone know what contacts the neg side of the push button to the body or the handlebars. If I use a wire to make the jump it all works ok.
Re: Starter switch
« Reply #5 on: July 22, 2023, 10:39:48 PM »
If I'm thinking correctly, I think there should be a pin/dowel in the bottom half of the switch case that fits in a hole in the handlebar. It depends which type of switch gear you have though.
« Last Edit: July 22, 2023, 10:41:28 PM by Nurse Julie »
Offline gary123
Re: Starter switch
« Reply #6 on: July 22, 2023, 11:01:19 PM »
OK, Thanks Ill check that out in the morning.
Re: Starter switch
« Reply #7 on: July 22, 2023, 11:02:35 PM »
Look inside the switch and tell me how many wires go to the starter button, there are two type of switch which work differently
Offline gary123
Re: Starter switch
« Reply #8 on: July 22, 2023, 11:09:04 PM »
Two wires, black and red/yellow.
All the wiring diagrams show an earth which is what I confused by.
Re: Starter switch
« Reply #9 on: July 22, 2023, 11:09:45 PM »
Good call Bryan. If you have two wires they should be a black live feed and a yellow / red out. The Black live feed may also come from a connection from the left switch  ;)
Re: Starter switch
« Reply #10 on: July 22, 2023, 11:11:28 PM »
Earth is for the earlier switch which is your handle bars ;)
Re: Starter switch
« Reply #11 on: July 22, 2023, 11:22:06 PM »
Your switch maybe for a 550 if it has two wires to the start button >>> http://manuals.sohc4.net/cb550/technical_reference/WD550C.jpg
You can see the differences here >>> http://manuals.sohc4.net/cb500/service_manual/HSM500550_11.pdf
« Last Edit: July 22, 2023, 11:24:50 PM by Trigger »
Offline gary123
Re: Starter switch
« Reply #12 on: July 22, 2023, 11:38:42 PM »
I think your right, Ill see if I can find another switch. Got a few in the junk pile
If not Ill improvise.
Re: Starter switch
« Reply #13 on: July 22, 2023, 11:48:48 PM »
You can Improvise, it is just a bit of sodding about with the wiring  ;)
Re: Starter switch
« Reply #14 on: July 22, 2023, 11:53:29 PM »
