Author Topic: I feel sure this has been covered before....500 K1 clutch...  (Read 355 times)
It is possible I misplaced a part but should there be a thrust washer or shim between the clutch outer basket and the gearbox bearing ?
Is there a previous post covering the correct assembly order  of the clutch operating mechanism thus working out what size shim is needed. I have done some trawling with no joy - lots of posts on various issues but no definitive advice found on best practice.
Thanks in advance.
Re: I feel sure this has been covered before....500 K1 clutch...
« Reply #1 on: July 26, 2023, 10:47:20 AM »
Dont think there is a washer behind the clutch basket but check in parts book Ted.
The adjustment shims go under the circlip holding the hub on from memory but again check parts and Honda manual for position and free play required
« Reply #2 on: July 26, 2023, 10:50:52 AM »
I've checked the parts book - it does not show one - I did wonder if it was shown in a different section somewhere. I'll disregard my Haynes manual.
« Reply #3 on: July 26, 2023, 11:14:30 AM »
The haynes purports to cover all the small fours and i think there may be one in the 400 Ted
« Reply #4 on: July 26, 2023, 11:54:38 AM »
That's the trouble with multi model manual - my 400 definitely had one.
« Reply #5 on: July 26, 2023, 04:04:21 PM »
I usually try fitting the shims until the circlip won't go on and then remove them one at a time until it does. Works for me.
« Reply #6 on: July 26, 2023, 04:52:17 PM »
Thanks Ken that is the direction I was heading towards.
