Author Topic: New member, Herefordshire  (Read 1314 times)
Re: New member, Herefordshire
« Reply #15 on: August 03, 2023, 03:34:12 PM »
45000 isn't that high. My K reg last time I rode it was at 163,000 and it's been clocking up the mileage in the 5 years since then. My L reg is stuck at around 263,000 until I get the bugger back on the road, going for a target of 500,000 on that one.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #16 on: August 03, 2023, 05:47:15 PM »
Hello again,
I don't have any experience of nickel plating, only zinc. Many of the forum members have zinc plating kits from Gateros, although others are available from the web.  As with any finishing process (painting, plating, polishing) the key to a good finish is in the preparation - a bit like computers - garbage in, garbage out!  Living in Orkney, I hate sending anything away, just in case it disappears in transit.  It's a time consuming job but very satisfying when you see the results.  Having a variable current/voltage stabilised power supply makes life easier but not essential.
There might be a re-posted piece on my site in the 'What's New' section with a brief account of how I do it.  If you do need nickel plating, the processes are very similar.
Ian
« Reply #17 on: August 03, 2023, 06:27:25 PM »
The latest kits from Gateros are zinc/nickel Ian, I've got one but for some reason or other I keep not setting it up.
Offline DomP
« Reply #18 on: August 03, 2023, 06:46:30 PM »
Ah yes zinc plating sorry, I was getting carried away  :)
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
