Author Topic: HDMI cables  (Read 655 times)
HDMI cables
« on: August 08, 2023, 04:33:06 PM »
Question for all the tech geeks on here.
I just had all my TV cables hidden in the wall and plastered over. Connected everything up afterwards and there's no signal. ☹ The 2 satellite cables to Sky Q box are working fine but the long HDMI cable is not connecting.
I thought that the HDMI cable in the wall must have been damaged so tried a short cable direct from the sky box to TV and it worked fine. Electrician had another new long cable in his van, same as the one fitted. We tried that direct between the devices and no signal! He then tried the cable at his house with a Virgin box and says that it works!
All the cables are High Speed HDMI with Ethernet, the only difference is the length. Original cables are 1.5m and wall cable is 5m. Electrician is no help, just says talk to Sky. Any ideas?
Offline Multiman
Re: HDMI cables
« Reply #1 on: August 08, 2023, 05:18:52 PM »
Just googled and found this sky forum.
https://helpforum.sky.com/t5/Sky-Q/No-signal-with-new-hdmi-cables/m-p/4356343
Suggests the longer the cable the better quality required
Did the 5m cable work before being plastered into the wall?
Re: HDMI cables
« Reply #2 on: August 08, 2023, 05:37:00 PM »
Thanks. Electrician didn't check it first because it was brand new and no TV equipment in the room. Completely emptied for plastering the ceiling as well. His spare cable doesn't work either, so I think it's the length or quality that's the problem.
Re: HDMI cables
« Reply #3 on: August 09, 2023, 09:29:20 AM »
I bought an expensive high quality HDMI cable 3m long. Bank loan required!
Everything works ok now. Just need to chip out the dodgy cable and plaster again. 😠😠
Re: HDMI cables
« Reply #4 on: August 09, 2023, 11:33:43 AM »
Lesson learned eh?
I’ve thrown out too many cheap cables. They look such a good deal…
2022 Tiger Sport 660
Re: HDMI cables
« Reply #5 on: August 09, 2023, 11:35:55 AM »
Can you pull it through using the old one.
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
Online McCabe-Thiele (Ted)
Re: HDMI cables
« Reply #6 on: August 09, 2023, 12:16:28 PM »
If you have to dig the plaster out to replace the cable fit some conduit so you are future proofed.
Use conduit a tad bigger to allow for extras.
« Last Edit: August 09, 2023, 12:18:01 PM by McCabe-Thiele (Ted) »
Re: HDMI cables
« Reply #7 on: August 09, 2023, 02:53:33 PM »
Unfortunately no, it's cable clipped to the wall. 😫
Re: HDMI cables
« Reply #8 on: August 09, 2023, 02:54:12 PM »
Certainly will. 👍
