Author Topic: Doms CB550F1 project  (Read 75028 times)
Offline DomP
Re: Doms CB550F1 project
« Reply #570 on: May 22, 2024, 01:39:22 PM »
Pics of instructions
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #571 on: May 22, 2024, 07:48:05 PM »
All sorted thanks to the legend that is Roo.  Well almost, the neutral light comes on then hors out but I'm sure it's an easy fix
1975 XS650B
« Reply #572 on: May 22, 2024, 09:54:26 PM »
Roo a legend - he will wear that accolade as a hard earned well deserved  badge of honour.👍👍👍
« Reply #573 on: May 23, 2024, 04:33:42 PM »
To quote a good friend of mine, you know what’s at the leg end?
Yup, an arse
It’s great what you can gleen from a phone call or two to try a remote diagnosis.
Happy you’ve sorted it Dom
Offline DomP
« Reply #574 on: May 25, 2024, 08:42:35 AM »
I've fitted led indicators to both front and rear of my 550, the two wire rears work perfectly but I'm having a few issues with the fronts, that is they don't work at all.  Now I think this is due to their three wire set up, I should mention at this point that I also have a new Koso gauge so therefore an led dash indicator.  Am I correct in saying I need to fit diodes and reco figure the current 3 wire configuration?
1975 XS650B
Offline DomP
« Reply #575 on: May 25, 2024, 10:42:45 AM »
Bit of an update, made up a gauge and ignition brackets out of 2mm steel bent in a vice with lots of mapp gas, lots of hacksawing and even more filing.  Really happy with the results!
1975 XS650B
Offline DomP
« Reply #576 on: May 25, 2024, 10:45:23 AM »
Ignition bracket
1975 XS650B
« Reply #577 on: May 25, 2024, 11:30:22 AM »
Good bit of Metalwork there Dom - always a nice feeling to make something yourself.
Offline DomP
« Reply #578 on: May 25, 2024, 12:57:05 PM »
Thanks Ted!  Do you know if I'm barking up the right tree with my led's as I think you've done similar?  Currently the fronts won't light up at all.
1975 XS650B
« Reply #579 on: May 25, 2024, 02:35:26 PM »
With some LED's they need connecting with the right polarity - hope I'm not insulting your intelligence.
Some LED's are not Polarity sensitive but probably  most are.
I tested mine with a slave battery - some come with good instructions.
« Last Edit: May 25, 2024, 02:37:18 PM by McCabe-Thiele (Ted) »
« Reply #580 on: May 25, 2024, 02:44:57 PM »
Nice work on the instrument bracket. It looks very professional.  👍
Are the 3 wire front indicators made so that they can be used as daytime running lights (as in USA)?
If so you can leave the running light wire disconnected, not used. The other 2 wires would be power from flasher relay and earth. Just need to identify which is which.
LED indicators either use a resistor in each indicator wire with the original flasher relay or use an LED electronic flasher relay which doesn't need resistors.
Offline DomP
« Reply #581 on: May 26, 2024, 07:55:34 AM »
The new indicators are two wire, I've tried them in just about every combination but can't get them to work on th front, the rears are fine however.  I've fitted a new relay to run leds as well
1975 XS650B
« Reply #582 on: May 26, 2024, 08:39:30 AM »
Have you tried switching the front bulbs with the rear?
Tested the front bulb holders using a test lamp?
« Last Edit: May 26, 2024, 08:41:04 AM by McCabe-Thiele (Ted) »
Offline DomP
« Reply #583 on: May 26, 2024, 09:05:28 AM »
I think I'll try this today Ted, I'll plug in an original lamp first.  They were working before so with checking again before I go any further
1975 XS650B
Offline DomP
« Reply #584 on: May 26, 2024, 10:20:07 AM »
Retracing my steps paid off, when I've fitted new headlight brackets they mount onto plastic bushes so I had a break in the earth.  Moving the ground wires to some spare plugs fixed it!
1975 XS650B
