Author Topic: Need advice re silencers  (Read 352 times)
oldchuffer
« on: August 17, 2023, 06:08:08 PM »
I have two silencers in good condition externally, looking at the internals i can see an internal pipe, on one the gap between this and the outer wall is larger, is that a problem. Also i took out some mangled what looks like a gasket or seal from inside the pipe, i'm assuming its a gasket which comes with the "clamp and gasket" set but it seems quite soft.
Sorry for the rambling but i'm a bit confused.  Many thanks for any advice. [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Re: Need advice re silencers
« Reply #1 on: August 17, 2023, 06:11:43 PM »
The soft stuff is to stop the inner pipe rattling against the outer skin  ;)
