Author Topic: Left side handlebar switch question?  (Read 2064 times)
Online McCabe-Thiele (Ted)
Re: Left side handlebar switch question?
« Reply #45 on: October 29, 2023, 08:35:24 PM »
I have just found a spare female slot in the four way Brown/White trace connector block in the headlamp.
Plugged in the wire mentioned above Black/Yellow trace into the Brown/White slot - side lamps work as do the parking lights with no idiot lights or ignition powering up.
Been here before but looks as if its now sorted. Only wires that are not colour matched inside the headlamp is the aforementioned Black/yellow trace from right bar switch then lastly the odd bridge as below.
I have made a bridge to connect the following wrong colours:-
Left bar switch (Male Bullet) Black/Yellow Trace to Right bar switch (Male Bullet)  Black/Red trace.
RESULT !!  Just need to coax everything back into the bowl without losing anything. ;D ;D ;D
I hate to fess up but I suspect that when I was fitting the headlamp back into place a couple of weeks ago  a wire fell out & I put it in the wrong connector.
« Last Edit: October 29, 2023, 08:54:06 PM by McCabe-Thiele (Ted) »
