Author Topic: stator overheating  (Read 1410 times)
Offline florence
Re: stator overheating
« Reply #15 on: September 01, 2023, 03:09:56 PM »
I have seen modifications where 15A fuses are put inline with the three stator wires as a prevention.  Might help diagnose without burning out another alternator stator.
Online Bryanj
« Reply #16 on: September 01, 2023, 03:47:00 PM »
15amp way too big per phase, total output of all three not that
Offline Brian Cairns
« Reply #17 on: September 01, 2023, 06:02:25 PM »
I'm wondering if the heat is actually caused by friction. Few reports lately where the rotor casing wasn't fitted with the 2 dowels that locate it properly, this caused the casing to sit a little skew and that caused the rotor itself to start to catch on the stator and the field coils. Any sign of rubbing on those? Also make sure the dowels are in place. If they are missing when you look, unless you know they are meant to be there you'd not know they were missing.
This is exactly what happened to mine, you MUST have both dowels fitted.
Hi , please excuse my ignorance, do i have to pull the rotor to check if dowels are in place, where are they located?
Brian
« Reply #18 on: September 01, 2023, 06:04:20 PM »
Just the cover Brian!
1978 Honda CB550K3.
« Reply #19 on: September 01, 2023, 06:10:42 PM »
Brilliant, thank you.
Brian
« Reply #20 on: September 01, 2023, 07:09:11 PM »
If you do find the dowels are missing Brian, I have some here. They are No.11 on the fiché
« Reply #21 on: September 02, 2023, 08:09:03 AM »
(Attachment Link)
Thanks, will do.
Brian
« Reply #22 on: September 11, 2023, 07:53:13 PM »
UPDATE:
I now have bike sorted.
My mechanic ( now ex-mechanic) installed the new regulator/rectifier incorrectly, in fact  he did not install the one I gave him at all, he used a rectifier he had in stock but still managed to wire it up incorrectly.
I got an auto spark who sorted it.
I took bike for a 25 mile run and then using an IF temperature gun, I measured the following temps.:
Fins ; 120 oc
Stator/Rotor side casing 72 oc
electronic ignition side casing 68 oc.
This all seems normal.
Bike is running really well, I have to install the spring on the choke rod for the carb yet.
I can get bike easily up to 80 mph but not much there after.
Idle sitting at 1200 rpm.
Thanks for all your help
Brian
« Reply #23 on: September 11, 2023, 08:59:32 PM »
What spring on choke rod?
Should get beyond 80mph quite easily, should really only start to struggle after 100mph.
« Reply #24 on: September 11, 2023, 09:21:54 PM »
UPDATE:
Fins ; 120 oc
Brian
Many cowboys about that think they know what they are doing is correct  ;)
Next time you take the bike out rev to 7000 rpm and change gear at those revs and see if it is still sluggish. If you are still struggling to get it past 80 mph, have a look at your float height's to check that you are getting enough fuel.
« Reply #25 on: September 11, 2023, 10:21:22 PM »
Ok Thanks.
There are 2 springs which are on the choke rod linkage in the carb unit. The larger spring opens up 2 carbs and the smaller spring ( which essentially joins the rods) opens up the other 2. The smaller spring was missing. Half choke opens up the 1st 2 carbs the smaller spring ( which essentially joins rods together) open ups the other 2 carbs when on full choke. Previous owner tried to use copper wire as a replacement for the smaller spring, apparently this is a common ‘hack’. Mind you my ex-mechanic might have lost the spring. I persuaded my original and trusted mechanic who i have been using for years to come out of retirement to sort my bike, he told re-done the carbs and synced them , he told be about the missing spring. I was lucky to get one of a motorcycle breaker on ebay. You could never buy the spring separately from Honda and they don’t make the whole linkage at all now.
